Author Topic: to change the thermostat or not?  (Read 4448 times)
jonathanh
  • coventry
« on: 29 March 2012, 09:16:08 »
i'm, getting quite a bit of fluctuation in temperature these days.  running quite cold on a long run but rapidly getting all fans on in traffice
normally I'd live with it but i'm changing cam cover gaskets over easter - does it make sense to do the thermostat at the same time?
If so, should I get VX or will pattern do?  and what gaskets/ seals or o rings do I need if it is worth doing?
thoughts?
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: to change the thermostat or not?
« Reply #1 on: 29 March 2012, 09:45:04 »
might as well as you got to get the water out to do the head. would make sense :y
Solar charger fitted.
If not Broke dont fix it..
PAULCDX
« Reply #2 on: 29 March 2012, 09:49:08 »
I had a temp fault where the gauge wouldn't move at all and I had no heating in the car. Turned out to be the stat was stuck open......
Regarding the cam gaskets, I would recommend you contact AndyC on here and he will do you a good deal on genuine VX gaskets, O rings and sealant  :y
As said, may aswell change the stat the same time to see if it cures your fault  :y
jonathanh
  • coventry
« Reply #3 on: 29 March 2012, 13:24:59 »
many thanks
what's the view here Vx stat or pattern?
SteveAvfc.
    • Mv6 2.6 V6
« Reply #4 on: 29 March 2012, 15:50:37 »
many thanks
Vx
martin42
« Reply #5 on: 29 March 2012, 21:19:45 »
im using a unipart thermostat,and so far no problems £11.50 compared to £40+
PAULCDX
« Reply #6 on: 29 March 2012, 22:16:57 »
Defo use only VX genuine cam gaskets and O rings. Andy C will sort you out a good deal  :y
I got my stat of ebay brand new £25 made by Whaler  :y
amba
  • Medway towns
    • German V6
« Reply #7 on: 29 March 2012, 22:26:02 »
Vaux-world sell  genuine VX supplied Wahler with GM part number stamped into housing for around £21 delivered and would be the same as you bought from stealers. :y
hotel21
  • The Kingdom of Fife
« Reply #8 on: 29 March 2012, 22:47:45 »
Sometimes you post good stuff, sometimes you post cack.   :o
Unless I read the original post very very wrongly, you yet again give absolute 'dangle berries' as advice, I'm afraid to say.
OP was asking about rocker gaskets, engine temp fluctuations and whether to change the water pump at the same time as the rocker gaskets.  There was no mention of changing the head or its gasket until you brought it up?  If the rocker gaskets are leaking that is the square root of fek all to do with the temperature fluctuations.
Please read the manual or in this case, RTFP.   :y
Please take more care Rusty.....   :)
« Last Edit: 30 March 2012, 00:04:52 by hotel21 »
hotel21
« Reply #9 on: 29 March 2012, 23:01:57 »
To OP.
You can change the thermostat without changing the heads.
http://www.omegaowners.com/forum/index.php?topic=90603.0
Point 16 is the infamous b'stard bolt.  Please feel free to do a forum search on the matter as there is more than a little info available on this challenge.   :y
Good luck!!   :)
buttsy19
  • gateshead
    • omega 2.2 cd, mini cooper
« Reply #10 on: 30 March 2012, 07:01:52 »
OP did not mention anything about the water pump, read the first post "thermostat" he is talking about.
Someone else needs to take more care,  ;D
If it aint broke, break it, then fix it
hotel21
« Reply #11 on: 30 March 2012, 07:20:43 »
Very true.   :-[   ;D
Just got my dander up a little last night!   ;D
Page created in 0.026 seconds with 20 queries.
