Author Topic: Which shocks to buy?  (Read 5845 times)
Mr Hagon
  • South West London
  • RWD and V6; the only way to travel!
« on: 30 March 2012, 00:18:11 »
So, I made the trip to WIM today and it was a very short one, albeit one that didn't cost me anything  :y.  I will, of course, be returning.
Both the wishbones are shot, so a pair of Lemforders will be ordered from All German Parts in due course (yes, I've decided against poly bushes for now).
However the o/s/r shock looks in poor health, as the picture shows.
As this is an Elite estate and I have the pipe going on to the shock, I'll assume it's the self levelling system and in order to maintain this I would need to buy the GM shocks (on TC of course) as a pattern part, say from Monroe, won't immediately fit.
Can someone confirm this, as a search of the site hasn't made this clear in my mind.
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
mathewst
  • Split, Croatia
    • v40
Re: Which shocks to buy?
« Reply #1 on: 30 March 2012, 00:21:49 »
to my knowledge only gm parts will fit but are too expensive
You can always replace rear shocks and springs and turn off the air suspension.
Last non leveling rear shocks on my previous mig were KYB and I would recomend them
davethediver
  • Blackburn, Lancs.
« Reply #2 on: 30 March 2012, 00:28:04 »
Ditch the self levelling side of things and fit pattern shocks may have to disconnect the pump or something but sure that's what a lot on here have done :y
P.A. Caron de Beaumarchais
mathewst
  • Split, Croatia
    • v40
« Reply #3 on: 30 March 2012, 00:34:23 »
I think he needs to replace the spring also but there are plenty second hand springs available there in UK as opossed to here >:(
Mr Hagon
  • South West London
« Reply #4 on: 30 March 2012, 00:39:27 »
Yup, if I ditch the self levelling shocks, then I need new springs.  Given that s/l shocks on TC come out at £150 + VAT I can live with that as that's roughly the same price for Monroe air shocks.
« Reply #5 on: 30 March 2012, 00:43:41 »
Depends on your needs. If you tow, carry heavy loads, have an Estate, then keeper the SL system as standard.
If saloon and you don't carry much weight, then fit a non SL shock of choice to improve handling. However if the springs are SL as well they will also have to be changed to match the new shocks as they are way too soft without SL shocks to support them. The new shocks will leak/fail in short order, and the car will sway and wallow.
IMO either keep as standard Elite SL. Or change the full suspension set up. With the exception of plod spec suspension with SL or similar combinations.
Need more info, do you need SL?
(cross posted your last)
Mr Hagon
  • South West London
« Reply #6 on: 30 March 2012, 00:53:24 »
Don't tow, only carry heavy loads when going on holiday in UK, but its an Estate so....
...will keep the SL as ditching it means new shocks and springs.  Question is, is the only way to do this by buying the GM SL shocks; i.e. no other pattern manufacturer/part is available at a cheaper price.  If this is the case then fine, will just get the GM shocks on TC via andyc.
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #7 on: 30 March 2012, 06:46:20 »
I've only ever come across Monroe units. Are they more expensive than the genuine ones? One of mine is starting to mist slightly so guess they will need doing at some point
« Reply #8 on: 30 March 2012, 10:18:26 »
Gm only.
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
« Reply #9 on: 30 March 2012, 10:26:01 »
That's what I dine but make sure you do them in pairs or you will have an uneven suspension and need to replace again soon paid 24 on TC from local factors  ;D
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
SteveAvfc.
    • Mv6 2.6 V6
« Reply #10 on: 30 March 2012, 16:31:03 »
Just purchased a set of genuine Vx rear shocks from Vauxhallworldparts.com  yes genuine Vx £101.00 delivered not self levelling though but you can do with out self levellers  :y :y
    • 530D M Sport, 330i Coupe
« Reply #11 on: 30 March 2012, 21:11:55 »
Shame it's an estate, I have a pair of self levellers from a saloon with about 30K on them and will have another pair with about 12K on them later in the year.
« Reply #12 on: 31 March 2012, 09:48:48 »
GM only for self levellers.
If you go non self levelling, you need to change the springs as well.
If you are happy with the Elite ride, stick with the levellers.
Mr Hagon
  • South West London
« Reply #13 on: 31 March 2012, 11:22:53 »
Shame but at least I can get them cheaper on TC.
Mr Hagon
  • South West London
« Reply #14 on: 31 March 2012, 11:24:53 »
Thanks TB, a sweet and succinct answer.  I am happy with the ride and don't want to worry about change the springs too, so GM self levellers are the way to go, via TC  :y.
