Author Topic: Cruise fitting woes...  (Read 2901 times)
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« on: 31 March 2012, 15:28:08 »
Hello all, I think I'll change my name to "Problem Child"  ;)
Anyway, today I WAS going to fit my cruise control but.... I started with the servo...
After I found where it goes, I removed the Aux Water Pump and put that out of the way (I'm guessing I need a different mount for the pump?)
I then fitted the servo to the inner wing, connected the harness and plugged in the cable to the servo, then I fitted the cable to the bracket on the Plenum Chamber, this is where things get wooly for me.... Is there a different bracket or cable or an adjustment to be made????
« Last Edit: 31 March 2012, 15:30:21 by HockeyDave55 »
Re: Cruise fitting woes...
« Reply #1 on: 31 March 2012, 15:31:31 »
I then fitted the servo to the inner wing, connected the harness and plugged in the cable to the servo, then I fitted the cable to the bracket on the Plenum Chamber, this is where things get wooly for me.... Is there a different bracket or cable or an adjustment to be made??..
take the accerator cable off first ie unclip the clip from around the ball & then pul it off (can be a bugger to copme off though) fit the cruise cable on the shaft the accelerator cable has jus come from, then refit the accerator cable.  :y
HockeyDave55
  • Milton Keynes
« Reply #2 on: 31 March 2012, 15:38:56 »
Sorry, edit... The actual problem, which I forgot to write is that the inner CC cable doesn't reach the throttle lever... Sorry!
« Reply #3 on: 31 March 2012, 15:58:01 »
Two lengths of Bowden cable. One for short plenum, one for long
HockeyDave55
  • Milton Keynes
« Reply #4 on: 31 March 2012, 16:06:03 »
Is it just the inner that's different?
« Reply #5 on: 31 March 2012, 16:08:19 »
As Rob says the early 3.0 and the 2.5 have a shorter cable than the later long plenum 3.0
HockeyDave55
  • Milton Keynes
« Reply #6 on: 31 March 2012, 16:12:11 »
I'll see if I can find one, Many thanks RobG and Pete! :y
« Reply #7 on: 31 March 2012, 16:13:04 »
Think Elite Pete may have one ;D ::)^^^^^^^
« Reply #8 on: 31 March 2012, 16:16:20 »
As if by magic ::)  Yep got one or two here :y
Cheers Rob :y
« Reply #9 on: 31 March 2012, 16:18:02 »
Cheers Rob :y
Thought you might 8)
HockeyDave55
  • Milton Keynes
« Reply #10 on: 31 March 2012, 16:20:10 »
Lol... That is funny!!! PM me and we'll go from there, I don't suppose you have the mount for the Aux Water pump???  ;D
Zippy2012
  • Worcester uk
    • 99,3.0 MV6 Est Ex Police
« Reply #11 on: 02 April 2012, 11:53:48 »
Are you retro fitting this unit??? im guessing you've got the indicator cruse Stalk?? 4pin switches for the clutch & brake pedels??
Because i fitted a unit onto mine & stalk but nobody told me i needed 2 more sensor switches to make it work!!!!
HockeyDave55
  • Milton Keynes
« Reply #12 on: 05 April 2012, 06:05:29 »
Yeah, it's all in except the kit I have is from an early 3.0, I am just waiting for the longer actuator cable.
