Pages: [1] 2 3 4 5 6 7 8   Go Down
Author Topic: Car is getting me down . Still overheating !!!  (Read 31927 times)
« on: 02 April 2012, 19:58:07 »
So im back to sqaure one after replacement of :
Radiator
HBV
Thermostat
Bridge seals ect ect
The car will gradually heat up and up till it goes into the red after 10-15 miles . When i pop the bonnet i can hear slight hissing from the back of the engine so could this be the non vx HBV at fault but i must add that there are no coolant leaks anywhere . :(
Im beginning to give up hope on keeping the car at this rate as much as i like it , any help appreciated even in person from anyone on here that can solve this for me .
Many thanks .
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
Re: Car is getting me down . Still overheating !!!
« Reply #1 on: 02 April 2012, 20:02:23 »
I was getting this a while ago.... Try parking with the car facing uphill, put your heating on hi and pull the hose on the throttle body.
You might have an air block and this is the highest point so give that a try and top the girl up!
Hope that helps  :y
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #2 on: 02 April 2012, 20:03:10 »
Water pump maybe?
« Reply #3 on: 02 April 2012, 20:03:51 »
Check header tank cap/neck .. a leak from either small cracks in the neck or a knackered cap seal can give similar symptoms
« Reply #4 on: 02 April 2012, 20:06:32 »
Hope that helps  :y
Thats about the only thing i have not tried dave but ill give it a go  :-\
Header tank is pressurising like there's too much air in the system and it has poured out water once when its overheated  ???
« Last Edit: 02 April 2012, 20:10:50 by eatmydust »
« Reply #5 on: 02 April 2012, 20:33:28 »
Hope that helps  :y
If it's leaking water from the cap then the cap is leaking .....  !!!  have a read here ..especially the solution right at the end !!!
http://www.omegaowners.com/forum/index.php?topic=101140.0
Also read this post
http://www.omegaowners.com/forum/index.php?topic=101516.0
Then check your header tank cap and neck ....   :)
flyer 0712
« Reply #6 on: 02 April 2012, 20:43:14 »
Hi   i have found in the past with air locks that i put the car up on car ramps or jack up the front as high as possible..with engine running..rad cap off this causes the air to dispel .
« Reply #7 on: 02 April 2012, 21:45:50 »
Is it normal for the water to start spewing out the bottle with the cap off ?
Hope that helps  :y
I have just tried this and its still overheating  :(
So its either header tank or cap now then or worse still the core plug !! If it was the core plug wouldnt the car be losing water rapidly as ive seen no water loss/leaks at all  :-\
HockeyDave55
  • Milton Keynes
« Reply #8 on: 02 April 2012, 21:50:04 »
I think you have an air lock.... Maybe???
Actually, that's exactly what mine was doing 'til I got all the air out...
« Last Edit: 02 April 2012, 21:54:02 by HockeyDave55 »
« Reply #9 on: 02 April 2012, 21:52:13 »
I really dont know what to do now dave , done as much as i can to resolve this but it still keeps overheating .
HockeyDave55
  • Milton Keynes
« Reply #10 on: 02 April 2012, 21:54:31 »
See edit above....
doz
  • Southampton
« Reply #11 on: 02 April 2012, 21:55:25 »
Have you felt the radiator? Is it getting hot?
« Reply #12 on: 02 April 2012, 21:58:20 »
Yes the rad is getting hot doz  :y
The temp needle falls when its revved  ???
But when its driven it will just overheat .
« Last Edit: 02 April 2012, 22:01:02 by eatmydust »
HockeyDave55
  • Milton Keynes
« Reply #13 on: 02 April 2012, 22:03:00 »
I have read the head gasket rarely go, and IMO, if it was a core plug, you'd get water elsewhere....
Lift the front of the car, I don't think it needs much??? Open the header tank and loosen the small pipe on the TB but leave it on.
Run the engine and pull the small pipe, some water will come out but I think air will too.....
Keep topping up the tank and soon you should expel all the air....
HockeyDave55
  • Milton Keynes
« Reply #14 on: 02 April 2012, 22:04:26 »
Air lock!
Pages: [1] 2 3 4 5 6 7 8   Go Up
Page created in 0.022 seconds with 20 queries.
