Swaping NCDC for 2006
Started by zirk, 02 April 2012, 21:16:33
Quote from: zirk on 02 April 2012, 22:06:31
Quote from: RobG on 02 April 2012, 22:00:47
Quote from: TheBoy on 02 April 2012, 21:58:46
Quote from: zirk on 02 April 2012, 21:56:14
Quote from: RobG on 02 April 2012, 21:39:22
Quote from: zirk on 02 April 2012, 21:34:32
Quote from: RobG on 02 April 2012, 21:29:47
Two extra wires to run Chris and swap the stalk for the "button" one
Ok, thanks Rob, stalks easy enough, any idea on the 2 extra wires and what there for?
Think it might be 3 Chris, they run from the MID to the relacement stalk. TB knows which pins :y
Cheers again Rob, hopefully TB may read and post up, when His not too busy.
Keep up ;D
Chris is getting on a bit mind TB ;D ;D
Fingers work, mobile works, brain works most of time, its the getting it to happen together, multitasking, that lets me down.
How quickly you need info?
zirk
Was planning doing something this weekend, although currently down with Man Flu at the mo, as long as its do able I can rip out the NCDC this weekend with the view of fitting the 2006 and MID the weekend after if that helps.
Cheers Chris. ;)
Stalk has 3 connections:
A - R
D - S
C - Common
(use meter to determine)
A goes to MID, PIN 23
D goes to MID, PIN 24
C goes to a suitable 0v, there is one behind dash.
zirk
Quote from: TheBoy on 04 April 2012, 20:47:17
A - R
D - S
C - Common
Thats Great, thanks TB.  ;)
