Author Topic: Wanted TD ECU  (Read 2611 times)
Agemo
  • Cleethorpes
  • Insignia
Wanted TD ECU
« on: 03 April 2012, 15:46:35 »
Can't seem to post in wanted section,m not sure why but could you please move for me?
Wanted, replacement ECU for a 2000 Turbo Diesel. Mine has the letters "JM" so I suppose the new one will have to be the same. Other numbers are:-
2247368 203
078
BOSCH 0 281 001 428
Made in Germany
90 494 180
B 96006
I thank you.
« Last Edit: 03 April 2012, 16:01:05 by Agemo »
GmasterT
  • Cambridge
  • does that drifting thing...
Re: Wanted TD ECU
« Reply #1 on: 03 April 2012, 20:18:11 »
2.5? I think I have one, will dig it out and check the nos :)
Agemo
  • Cleethorpes
  • Insignia
Re: Wanted TD ECU
« Reply #2 on: 03 April 2012, 20:24:16 »
Thanks GmT, has to be Diesel 2.5  :y
Re: Wanted TD ECU
« Reply #3 on: 08 April 2012, 12:40:51 »
More than that - there are 4 different ones fitted to the UK spec TD, and yours is from a X25DT auto. Anything else is incompatible.
Agemo
  • Cleethorpes
  • Insignia
Re: Wanted TD ECU
« Reply #4 on: 08 April 2012, 17:06:13 »
Thanks TB, I am still after an ECU, transponder & key chip.  ::)
unlucky alf
  • worksop, notts
Re: Wanted TD ECU
« Reply #5 on: 10 April 2012, 20:49:28 »
Ive got one somewhere but not sure of the number on it, But the one thing I do know is that it is chipped to +10 :o, i`ll dig it out if there is enough light in the garage & check the number.
unlucky alf
  • worksop, notts
Re: Wanted TD ECU
« Reply #6 on: 10 April 2012, 21:01:50 »
Ive just dug it out & its a 0 281 001 427 & it came off a manual car by the way. :(
Agemo
  • Cleethorpes
  • Insignia
Re: Wanted TD ECU
« Reply #7 on: 11 April 2012, 15:30:12 »
Thanks Alf, but I have one on the way now (touches wood). I will update this post when it arrives. I do appreciate you looking it out though. The numbers on yours are correct apart from the very last digit, which makes it the wrong one. YourS is from a Manual, which  will not fit in an Auto, although apparently it works the other way round. If you are selling the ECU on it's own, it has to go on a Tech 2, and it should be "blanked" first, although early ones may be plug & play, (I am sure someone will confirm this). Thanks again, hope someone can make use of it.
Agemo
  • Cleethorpes
  • Insignia
Re: Wanted TD ECU
« Reply #8 on: 13 April 2012, 20:15:34 »
OK, all sorted, thanks to dieseld4. Thread can now be locked.  :y
