Pages: 1 [2] 3  All   Go Down
Author Topic: Big thank you to THE MASTER  (Read 10475 times)
Re: Big thank you to THE MASTER
« Reply #15 on: 08 April 2012, 12:35:10 »
I'm pleased to say that the gearbox ECU change seems to have cured the gear change problems. :y
Well blow me down with a feather :o
In the spirit of learning/OOF, next time you pass this way, fancy putting original back in, and we'll reapply the firmware, and see if that cures it... ...wondering if it went on corrupt? Can't remember if we flashed it originally, or if it was already at latest when you bought it.
Been flashed several times, you even put 2.5 solftware, then reloaded the 2.6.
The only thing I can think of is the original wasn't seating properly?
Suspect it would throw all sorts of codes, rather than just hang on to gears
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #16 on: 08 April 2012, 18:40:29 »
Been out for a good run today, knock got progressively worse, only appears to happen when cornering right :(
I like red cars
« Reply #17 on: 08 April 2012, 18:48:40 »
When steering passes through about 3 o'clock position?
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #18 on: 09 April 2012, 07:01:46 »
Sort of, yes.
Before it was happening as you turned a sharp right, say into a side road, now it seems to happen on all right bends.
« Last Edit: 09 April 2012, 07:03:42 by Auto Addict »
I like red cars
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #19 on: 09 April 2012, 11:24:47 »
Just a thought,
if all the steering joints have been checked and all APPEARS TO BE GOOD,  have the front sub frame mount bolts been checked for tightness, it is just poss that the bolts have become loose.
hope you find it will watch this with intrest.
Jaguar XJ6
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #20 on: 12 April 2012, 16:42:37 »
Knock is there nearly all the time now, started to happen on a left hand lock as well :(
I like red cars
« Reply #21 on: 12 April 2012, 16:47:58 »
You will have to pop up one evening so you can drive and I listen  :y
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #22 on: 12 April 2012, 16:52:05 »
Thanks, I'll be in touch :y
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #23 on: 13 April 2012, 10:53:31 »
I've tweaked the steering box up a quarter of a turn, which seems to have improved it, will report back when I've taken it for a proper run.
I like red cars
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #24 on: 13 April 2012, 11:27:56 »
Thi sis interesting, do you have some information or ideas to this 3 o'clock knok?
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #25 on: 13 April 2012, 18:41:27 »
It's better, but it's still there :(
I like red cars
« Reply #26 on: 13 April 2012, 18:59:02 »
Just trying to think how adjusting the steering box damper, which works in the straight ahead position, would affect a creak with steering off centre...? :-\
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #27 on: 14 April 2012, 05:34:45 »
Doesn't creak anymore, just got a knock you can feel through the steeering wheel.
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #28 on: 25 April 2012, 16:08:36 »
Interesting, doesn't seem to happen in the wet.
I like red cars
« Reply #29 on: 25 April 2012, 18:20:12 »
Water getting in and effectively lubricating the joint/or whatever ir is.
Pages: 1 [2] 3  All   Go Up
