Pages: 1 2 [3]  All   Go Down
Author Topic: Big thank you to THE MASTER  (Read 10476 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Big thank you to THE MASTER
« Reply #30 on: 25 April 2012, 21:36:05 »
Water getting in and effectively lubricating the joint/or whatever ir is.
That's what I thought.
I like red cars
« Reply #31 on: 25 April 2012, 22:16:48 »
"Might" be up in Brackley on 5th 6th. Can come tooled up this time if you like? If his lordship is about of course ;)
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #32 on: 26 April 2012, 07:28:19 »
Been out for a good run today, knock got progressively worse, only appears to happen when cornering right :(
Plot thickens... Seems to be exactly as mine, opposite direction though but you also have the steering on the wrong side so makes the problem the same. Any recent updates or ideas what maight be the cause?
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #33 on: 26 April 2012, 07:47:18 »
Got to book an appointment with the MASTER again ;)
I like red cars
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #34 on: 27 April 2012, 05:58:00 »
Its not something daft like a droplink is it  :-\
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #35 on: 27 April 2012, 11:24:39 »
Well, it's defo. a dry joint somewhere.
Yesterday it was dry here, and it was creaking and knocking like a goodun'.
Today, it's pouring down, and not a peep from it.
I like red cars
« Reply #36 on: 27 April 2012, 13:11:55 »
Top drop link ball joint woul be in the right area iirc. But it would have to be a dry joint rather than a joint with play.
Iirc the creak/knock was with steering wheel at about 3 o'clock. As the ball drop link is attached to the shock body, it "might" be a possible cause. Although master would have had to undo the bottom ball joint when he worked on it. :-\
Pages: 1 2 [3]  All   Go Up
