Author Topic: omegas a  (Read 1762 times)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
omegas a
« on: 04 April 2012, 22:45:03 »
i do a shop run say 8 miles . car gets warmed up . i stop for 2 min then when i restart it sounds like im firing on 3 pots .. then all goes good again..just done new plugs so i no its not them ..and the other day it cut out on tickover.as for dash lights ..it swaps between spanner on the car and the gearbox pic.......any ideas......... :'(
davethediver
  • Blackburn, Lancs.
Re: omegas a
« Reply #1 on: 04 April 2012, 23:35:42 »
My first idea is to get the codes read then we can maybe help with a diagnosis :)
If lights are on there is a fault code logged tell us that and the crystal ball may give a more accurate answer of what's up :y
P.A. Caron de Beaumarchais
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: omegas a
« Reply #2 on: 05 April 2012, 00:02:22 »
not yet another cam sensor problem maybe.
Steve B
  • Leicestershire
Re: omegas a
« Reply #3 on: 05 April 2012, 13:42:50 »
ok so ive had my code looked at and deleted.theres lots of them....
..............ENGINE.............
P0170 (2) lean exhaust-not present
p1555 (0) throttle position sensor (tps) load signal not plausable with engine load-not present
p0340 (4) camshaft position sensor circuit no signal-not present
p1700 (0) svs via can-not present
p0335 (8 ) crankshaft sensor incorrect signal-not present
.............transmission........
p1781 (0) unknown dtc-not present
p1625 (2) internal power control final stage low input-not present
p0727 (0) can receives error-not present
now i will see what comes back
« Last Edit: 05 April 2012, 13:48:45 by bigtimecube »
