Author Topic: Corsa CV boot  (Read 9937 times)
Corsa CV boot
« on: 09 April 2012, 15:46:28 »
Hi all , my daughter has had a quote from the garage to replace a n/s inner driveshaft boot ...Im thinking i can do this for her but is it a simple job as ive never changed one .
Oh the garage quoted her £140 , looking into the price of the boot but they said £40  :-\
Its a 1.0 on a 53 plate , manual  :)
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
Re: Corsa CV boot
« Reply #1 on: 09 April 2012, 15:53:12 »
Shouldn't be that difficult have you a cv splitter to put new boot over a garage should be hour labour and boot cost no more than £100 at best shop around try getting better price  :y
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
Re: Corsa CV boot
« Reply #2 on: 09 April 2012, 15:56:46 »
Whats a cv splitter , i have a ball joint splitter if thats any good  ;) and ive just spotted this on ebay ...
http://www.ebay.co.uk/itm/Vauxhall-Corsa-C-Inner-CV-Boot-Kit-1-0-1-2-/320884375412?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ab632ff74
Edit : Yes i have a c/v splitter  ;D
« Last Edit: 09 April 2012, 16:00:54 by eatmydust »
Re: Corsa CV boot
« Reply #3 on: 09 April 2012, 16:45:15 »
have in the past, with success, carefully fitted split boots to CV joints.  No dismantling necessary - just cut old boot and clips off, fit boot over joint by carefully "spreading" it, use rubber glue supplied to rejoin boot (needs care and cleanliness), refit supplied clips and jobs a good 'un.
Use these on big and small Rovers in the past.  No subsequent issues and passed MOTs ok
Re: Corsa CV boot
« Reply #4 on: 09 April 2012, 17:08:28 »
Thats an option , cheers dbug  :y
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
Re: Corsa CV boot
« Reply #5 on: 09 April 2012, 21:17:26 »
Haven't used anything but a CV cone for years. With drive shaft/hub split, its a 10 min job.
One from Fleabay http://www.ebay.co.uk/itm/VAUXHALL-CORSA-CV-JOINT-BOOT-KIT-CONE-GAITER-CV-BOOTKIT-DRIVESHAFT-CONE-/130676982973?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e6cf484bd
or this, just need boot & a bit of silicone lube http://www.ebay.co.uk/itm/Bailcast-CV-Boot-Fitting-Cone-Tool-DriveShaft-FC1-cv-cone-/330694326789
Wasn't a method I preferred until I tried it, wouldn'y do it any other way now. Find the 2 part boots don't last that long either, no matter how clean.
Good site  http://slide-a-boot.com/default.aspx   :y :y
Those are my principles, if you don't like them I have others.
Re: Corsa CV boot
« Reply #6 on: 09 April 2012, 21:29:14 »
Not sure exactly how that slider boot fitment works , if the cv joint does not need splitting then how does a fixed boot slide over  :-\ and the cone thing  :D
Do they have a split that needs re-joining and the cone is the template while you glue it ?
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
Re: Corsa CV boot
« Reply #7 on: 09 April 2012, 21:32:45 »
Drive shaft with CV splits from hub/disc. Cone goes over CV, slide new boot up and bingo!
Re: Corsa CV boot
« Reply #8 on: 09 April 2012, 21:35:50 »
Super stretchy  :y Thanks V8  :y
Re: Corsa CV boot
« Reply #9 on: 09 April 2012, 22:00:14 »
If its an inner cv joint then disconnect the bottom ball joint, pop the drive shaft from the cv joint (requires good circlip pliers) and fit a good quality one.
Boots are 10-20 quid (even for genuine).
Elite_L0ver
  • On too Omega #2
Re: Corsa CV boot
« Reply #10 on: 09 April 2012, 23:20:12 »
  what he said  ;D
Re: Corsa CV boot
« Reply #11 on: 09 April 2012, 23:33:47 »
Tis inner boot . £20  :o a bit different to the £40 quoted from the garage  >:( Daughter was in a panic about it as her MOT is in september  ::)
Think ill have it done by next week  :)
Elite_L0ver
  • On too Omega #2
Re: Corsa CV boot
« Reply #12 on: 10 April 2012, 00:00:08 »
ages away
if you can work on a mig you can do a corsa piece of pi33 :y ;D :D ;D :y
Re: Corsa CV boot
« Reply #13 on: 10 April 2012, 12:33:23 »
ages away
Omega was dead easy  :-X :-X :-X  ::) >:( ;D
Corsa 3 pot should be a doddle  :-X i took the corsa for a drive the other day , boy does it grunt at slow speed . Needs an extra 3 pots me thinks  :)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Corsa CV boot
« Reply #14 on: 10 April 2012, 15:36:20 »
Hi all,
Sorry if I have this wrong but don't garages normally offer to simply replace the axel these days due to cost?
RIP Paul Lovejoy
