Author Topic: Flat spot, 4000rpm - multirams?  (Read 1493 times)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« on: 13 April 2012, 11:11:25 »
When driving, er, briskly, there seems to be a flat spot around 4000rpm, which IIRC is the revs that the multirams activate? Once I've fitted my spangly new exhaust, I'll be investigating - after checking the vacuum pipes routing and fit, anything else I should be looking for?
Re: Flat spot, 4000rpm - multirams?
« Reply #1 on: 13 April 2012, 13:38:26 »
Flat spot... Or a step?
IME multi ram failed feels flat below 4k then takes off above 4k.
If a genuine flat spot, I'd check cam timing and for.... Maybe a Blocked exhaust. See what happens I guess. :)
« Reply #2 on: 13 April 2012, 13:55:32 »
Genuine flat spot - pulling through from 50 leptons* up through 3rd to 85 leptons, it pulls, then flattens about 3900-4000rpm, then pulls again.
*unit of speed, not dissimilar to MPH but on a *cough* private road....
« Reply #3 on: 13 April 2012, 14:20:32 »
worth trying to actuate them both using software to see if working OK?
« Reply #4 on: 13 April 2012, 15:47:38 »
That would be brilliant, sadly I don't think anyone has a Tech2 within 100 miles.
On the note of the blocked exhaust, I'll be taking it out tonight so will see if the new one has had any effect.
PhilCavSRi130
  • Stone,  Staffordshire
  • GRIFFIN POWER!!
« Reply #5 on: 13 April 2012, 21:47:28 »
Is it just a split second of a flat spot then it goes again?
If so this is as the dual ram comes in and is normal on the v6's. If its more than a split second will be something within the dual ram system holding it back i.e. broken vac pipe or faulty valve etc.
Page created in 0.008 seconds with 16 queries.
