Author Topic: Door removal  (Read 3164 times)
Door removal
« on: 13 April 2012, 15:54:08 »
Drivers door was damaged, got another to go on.
Any advice on removing and re installing the hinge pins? There is a specil tool apparently.
 ...or anything else relevant?
The door I have is off a higher miler, so the guts of my door will be going in the new one.
Ta
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: Door removal
« Reply #1 on: 13 April 2012, 15:55:56 »
Don't forget to support the handle end. That's all I'm saying. Not from experience. Ahem.
Re: Door removal
« Reply #2 on: 13 April 2012, 16:03:46 »
Ta
Installing, small tack hammer. Removing, I just use a flat-bladed screwdriver
Re: Door removal
« Reply #3 on: 13 April 2012, 16:10:56 »
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l2736&_nkw=door+pin+removal for the removal tool. Piece of wood undeer the door on a trolly jack to take the weight of the door.
I made this out of high carbon steel  :y
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
Re: Door removal
« Reply #4 on: 13 April 2012, 16:48:43 »
I always use a pair of molegrips clamped loosely  and tap them with a small hammer.  To refit just a small hammer.
bootie
  • Enix, Almeria, Spain
Re: Door removal
« Reply #5 on: 13 April 2012, 16:59:38 »
These pins the same as a carlton?
Dr_X
Re: Door removal
« Reply #6 on: 13 April 2012, 17:04:30 »
You can use your new super trolley jack to support the door  :y
Re: Door removal
« Reply #7 on: 13 April 2012, 17:06:18 »
Almost. Instead of being parallel all the way along, there's a small flair at the bottom of an Omega's door pin, it gives you something to hit!  ;D ;D
bootie
Re: Door removal
« Reply #8 on: 13 April 2012, 17:14:16 »
Right. It's just that this topic came up on ABS and there is a wonder tool that has been used very effectivley.
It's like a slide hammer, well in fact it is a slide hammer but the shaft is thin enough to go through the pin, where you then screw on a nut bigger than the pin and slide bang to get it moving. This method works well on older corroded pins as there is less chance of hitting the end obliquely and putting it out of shape.
Plus it's long enough to get down between door frame and door without fouling.
Jon
Re: Door removal
« Reply #9 on: 13 April 2012, 20:52:24 »
hammer and molegrips. Ideally a 2nd set of hands
Re: Door removal
« Reply #10 on: 13 April 2012, 20:58:12 »
Nah, rest the passenger door on left leg just above knee, driver`s on right one, seemples :)
Re: Door removal
« Reply #11 on: 13 April 2012, 20:59:37 »
Yeah, but this is gayboy :P
I'll bear your technique in mind, not tried that :y
Re: Door removal
« Reply #12 on: 13 April 2012, 21:00:57 »
Just watch your foot ;D
Re: Door removal
« Reply #13 on: 13 April 2012, 21:02:29 »
Ooooooo, bitch :P ;D
Re: Door removal
« Reply #14 on: 13 April 2012, 21:04:00 »
;D ;D
