Author Topic: What is does this connect to???  (Read 2556 times)
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« on: 13 April 2012, 18:50:09 »
While fitting a new coil pack, I noticed a vac pipe that has broken off something.
Any ideas??? I can't see anything????
It goes from here....
To..... Something at the rear of the engine???
You can see the broken end here but I can't find what it came from????
Re: What is does this connect to???
« Reply #1 on: 13 April 2012, 18:59:14 »
Rear multiram?  Or HBV?
« Reply #2 on: 13 April 2012, 19:05:53 »
Directly to the left of the broken part in the pic is a white plastic piece. It may have broken off there. Although the broken bit appears black.
It is definitely part of that vacume system though. So it will feed off the brake servo pipe and those associated parts.
« Reply #3 on: 13 April 2012, 19:06:53 »
Hbv vac pipe can be seen back right. So it's not that.
« Reply #4 on: 13 April 2012, 19:09:16 »
Actually, it's broken off the servo pipe. I can just see to remains of the nipple directly above the end of the white writing on the heater hose.
HockeyDave55
  • Milton Keynes
« Reply #5 on: 13 April 2012, 22:10:17 »
Has anybody got a pic of what it should look like???
HockeyDave55
  • Milton Keynes
« Reply #6 on: 13 April 2012, 22:23:50 »
Bingo! I just had a look and it has snapped off the servo pipe! Not sure how I can fix this one???? New pipe.... :/
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #7 on: 13 April 2012, 22:26:51 »
Just put a ad in the wanted section I'm sure somebody on here will have one for ya
HockeyDave55
  • Milton Keynes
« Reply #8 on: 13 April 2012, 22:28:49 »
Oh yeah! I'm over 250 now!!!
twiglet
  • Norwich, Norfolk
« Reply #9 on: 13 April 2012, 22:35:12 »
Got a couple of spares here Dave.  :y
HockeyDave55
  • Milton Keynes
« Reply #10 on: 13 April 2012, 22:54:27 »
I just put a request on the wanted section, PM me the details???
« Reply #11 on: 14 April 2012, 01:15:37 »
It's only the feed to the SAI valve. I'd bin the whole system but you do need to fix the broken off nipple on the brake servo hose as that's an air leak. Just remove the "T" piece with the broken end.
« Reply #12 on: 14 April 2012, 01:34:26 »
Ah, well of it feeds the SAI yeah don't worry. As Kev says just block the leak in the servo pipe.
Sorry, didnt think of SAI. Haven't had that on one of my omegas for years.
HockeyDave55
  • Milton Keynes
« Reply #13 on: 14 April 2012, 07:24:07 »
Why bin the SAI? What's the advantage?
« Reply #14 on: 14 April 2012, 08:53:39 »
No advantage, it does nothing anyway. Other than make a horrible noise on start up. Most people just unplug the electrical connector up under the bumper by the washer bottle. (iirc)
But it's more important to plug the hole in the vac pipe where that elbow came from.
Page created in 0.076 seconds with 16 queries.
