Author Topic: Question about the Omega B camshaft sensor (New sensor, but problem still is)  (Read 2133 times)
supersaw
  • Lithuania
    • 95' Omega, 2.0 16v + LPG
    • MappingTracking.com
Hi ;)
I have Omega B, 95' 2ltr 16v.
I have a problem, my rev limiter was @ 4.500.
The diagnostic show that the problem was with the camshaft sensor. I changed it. But the problem still is....rev limiter @4.500....
New Camshaft sensor is not from GM.
Do I need to reset errors manual or the car cpu see that automatically ?
Thanks for the help ;)
« Last Edit: 14 April 2012, 12:05:17 by supersaw »
Horsepower is how fast you hit the wall
Torque is how far you move that wall
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Not from GM
Thats the problem ... cheap pattern parts  :-\
Unless theres damage to the wiring .
If the camshaft code is still there replace with genuine GM .
    • 530D M Sport, 330i Coupe
Also worth rescanning just incase the crankshaft sensor is on it's way as well.
supersaw
  • Lithuania
So I need to re scan /reset errors? Ecu doesn't automatically see a new sensor ?
Proz
If the fault is " cured " the ecu will put the light off .
There must still be a problem so get it re scanned to rule out something else before replacing any more parts .
supersaw
  • Lithuania
Maybe there is a problem with wiring ? how can I check it ?
Need to scan, clear and rescan to see if any codes come back.
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
copys dont work, will make engine stay the same has to be original gm one and has to be first type some of these copys are the second type that may work on a 98 mig but not for long.
Solar charger fitted.
If not Broke dont fix it..
supersaw
  • Lithuania
It is ok. Problem is fixed. I just waited a little bit longer when removed clamps from accumulator. And now I don't see any attention signs.
