Author Topic: AUTO GEARBOX PROB  (Read 1740 times)
ree
  • Cambridge
    • omega 2.0 cd
AUTO GEARBOX PROB
« on: 17 April 2012, 21:55:57 »
Me Again  ;D ;D ,
Car drives and changes gears fine, until I stop and put in Neutral or Park, then it 'Clunks' in and out of both park and Neutral only happens when car has reached temp. It doesn't get hotter than 95, cant' be doing gearbox any good, they want £30 to check oil level, if oil is fine what else could it be? (New Box  :'( ?).
Thanks Again - Keeping you all busy tonight  :)
Ree
REELUIN
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: AUTO GEARBOX PROB
« Reply #1 on: 17 April 2012, 22:07:08 »
follow the guide and check it yourself. some dough saved and a sense of one up on the stealers  :y
RIP Paul Lovejoy
ree
  • Cambridge
    • omega 2.0 cd
« Reply #2 on: 17 April 2012, 22:21:13 »
Thanks for input. I have't got facilities to put car up, only got front wheel ramps, was under the impression it has to be level to be checked. Don't fancy lying underneath with axle stands!! :-\ and only ramps at front. Would the lack of oil (if this is the case) make it clunk in and out of park and neutral? Drives fine going thro gears, no hanging.
Ree
REELUIN
Webby the Bear
  • Northampton
« Reply #3 on: 17 April 2012, 22:28:03 »
Ree
fair enough mate. you only jack it up/on axel stands to remove plug and fill with top up fluid. then let it down so its level and then drain the remainder out and when done it's full :) check out the guide for info....
http://www.omegaowners.com/forum/index.php?topic=90508.0
as for what would cause that i personally dont know but id say this is the place to start :)
RIP Paul Lovejoy
ree
  • Cambridge
    • omega 2.0 cd
« Reply #4 on: 17 April 2012, 23:20:07 »
tx webby one more question for you when ive loosend the nut should fluid leak out at that point and if so dose this mean its not needed or because its jacked up one side its gonna happen anyway , ? will give it a try 2moz if that does not cure my clonking in and out of nutreal and park any other ideas ( or is box on way out  :'(  tx again.
Ree
REELUIN
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #5 on: 17 April 2012, 23:39:05 »
Check that first and then we'll see how it goes. Fingers crossed that's all it needs  :y
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #6 on: 18 April 2012, 21:01:42 »
Ree
need to have engine running before removing filler plug ,or it will run out  ;)
