Author Topic: Climate control stopped working.  (Read 1407 times)
Agemo
  • Cleethorpes
  • Insignia
« on: 18 April 2012, 16:31:25 »
OK, air-con & heating were working fine, then I noticed there was no heat in the car. I turned up the temp,- no difference. tried to speed the fan up, then realised it wasn't working. No matter what I do, I can't get the fan to operate. Tried the re-sync, and every button. I have a very small amount of heat coming into the car, but the fan will not work. Any ideas?
Re: Climate control stopped working.
« Reply #1 on: 18 April 2012, 16:46:18 »
Fuse #33 :-\
Agemo
  • Cleethorpes
  • Insignia
« Reply #2 on: 18 April 2012, 16:51:02 »
Thanks Rob, I checked every fuse but will have another look now.  :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 18 April 2012, 17:00:53 »
Rob, you are a star. I checked again, 33 looked ok, but I swapped it for another, and I now have my heating back. I have the old fuse in front of me & it looks perfect, but it could even be that there is a loose wire behind the fusebox. Thanks Rob.  :y
edit :- Just tested the fuse, nothing wrong with it, so it could be a connection. It works for now so will look in the Summer.
« Last Edit: 18 April 2012, 17:11:22 by Agemo »
