Author Topic: 2.5td lift pump - rewire  (Read 1845 times)
Vulpine
  • Kent UK
  • Omega 2.5TD The Vegmega!!
    • Omega 2.5TD '97
« on: 19 April 2012, 19:07:02 »
HI
Got a code 34 fault with full throttle hesitation and dieing.
Have already changed fuel filter.
Will check timing sensor on injector 4 next is reading 100ohms.
After this i am going try wiring the lift pump to be on constantly with the ignition.
So:
1) will this kill the pump in quick order?
2) which of the 2 pipes is fuel out and which is fuel back in to the tank?
thanks
Jon
Admin edit
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
Re: 2.5td lift pump - rewire
« Reply #1 on: 19 April 2012, 19:42:14 »
re- pipes , don,t know for sure but would guess the one on the right is fuel out .
Agemo
  • Cleethorpes
  • Insignia
« Reply #2 on: 19 April 2012, 19:52:03 »
If memory serves, you only need the pump when you are down to 20 odd litres. If your tank is say, half full, and it still dying or it hesitates, then you need to look elsewhere.
Vulpine
  • Kent UK
    • Omega 2.5TD '97
« Reply #3 on: 19 April 2012, 21:12:43 »
hhmm its on about 30 litres atm.
Admin edit
Agemo
  • Cleethorpes
  • Insignia
« Reply #4 on: 19 April 2012, 21:22:33 »
Your fuel gauge may not be reading perfect, so it's well worth filling up & see if it makes a difference.  ::)
