Author Topic: cruise control  (Read 2464 times)
shaun
cruise control
« on: 03 April 2008, 17:00:36 »
sorry people slight corsa post( still vauxhall though) so please help.
im looking at converting my corsa gsi so that it has cruise control. does anyone know if this can be done? many thanks
shaun
markey mark
  • SLady bitshorpe north lincs
Re: cruise control
« Reply #1 on: 03 April 2008, 17:12:48 »
would think so matey seen them fitted to cavvy gsi's  :y
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: cruise control
« Reply #2 on: 03 April 2008, 17:55:19 »
Moving to General Chat as not Omega related, sorry.
I like red cars
shaun
Re: cruise control
« Reply #3 on: 03 April 2008, 18:10:43 »
ok mate no problems.
anyone have any info for me please
Re: cruise control
« Reply #4 on: 03 April 2008, 19:22:25 »
Don't know the engine, but if DBW, it probably hasn't the code in the ecu to run cruise.  If cable driven, unless Corsas were ever fitted with cruise, may be easier just to get an aftermarket cruise kit.
Re: cruise control
« Reply #5 on: 03 April 2008, 19:24:07 »
Adding to that, a 1.6 (?) manual is never going to be that good on cruise, except on a steady motorway run - not the usual journey I suspect for Corsas....  :-/
Re: cruise control
« Reply #6 on: 03 April 2008, 19:35:06 »
Cruise is pretty easy to sort on a Corsa C although you do sometimes have to add a few wires......much harder on a Corsa B !
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: cruise control
« Reply #7 on: 03 April 2008, 20:25:02 »
If its a B, youd need to have a later model with electronic speedo, or if its an earlier one (GSi spec around 95) then you'd need ABS to get some sort of signal in regards to speed for the cruise.
You also then have the fun of routing the actuator cable, finding where to attach it to the throttle...  Then all the wiring to go with it (clutch switch & brake switch) which will be none-standard fitments so will need more work to fit...
As said, bit of a hard job, 'can' be done, but not really worth it.
Humbugs...
prestigesec
  • Wirral
Re: cruise control
« Reply #8 on: 03 April 2008, 21:28:00 »
Its a forum not the secret service guys chill out!
Re: cruise control
« Reply #9 on: 03 April 2008, 21:39:36 »
 :o
Re: cruise control
« Reply #10 on: 03 April 2008, 21:47:18 »
This is an Omega forum, therefore we only have Omega related problems in our Omega Help section ;).  Happy to discuss other cars in General Chat area :y
shaun
Re: cruise control
« Reply #11 on: 03 April 2008, 21:49:21 »
sorry guys forgot to say its fitted with a c20xe redtop engine
