Author Topic: loss of power  (Read 2287 times)
snipe
loss of power
« on: 21 April 2012, 17:41:55 »
Hi fellow membe
eml light came on no rev counter working engine sounds ok ie no misfire .Turbo seems not to be working .Arrived home , car stood for one hour re started everything seems now to be ok.eml light out .Car is 51reg 2.2Dti speedo 96000,
Re: loss of power
« Reply #1 on: 21 April 2012, 18:00:03 »
You need the codes reading that are stored :y
martin42
Re: loss of power
« Reply #2 on: 21 April 2012, 18:40:49 »
Crankshaft sensor
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: loss of power
« Reply #3 on: 21 April 2012, 21:16:35 »
x1  :y
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: loss of power
« Reply #4 on: 21 April 2012, 21:57:08 »
x1  :y
Divided by one and minus the original!
Crankshaft sensor
+1.
snipe
Re: loss of power
« Reply #5 on: 23 April 2012, 12:26:03 »
Hi all
codes showing are P1590 P1335 P0725 garage states cran sensor . Car is 51 2.2Dti .Codes have been cleared . Will this be the end of it?.Members thoughts and experiences would be appreciated . Location plymouth . Are there any good contacts in this area.Thanks in anticipation.
martin42
Re: loss of power
« Reply #6 on: 23 April 2012, 15:23:38 »
if  crankshaft sensor hasnt been replaced then no,use a genuine part tho  :y
snipe
Re: loss of power
« Reply #7 on: 23 April 2012, 15:56:50 »
Hi Martin
Thanks for the info EML back on again .Can you advise me of approxs cost of part and fitting .Wouldyou advise main dealer.Thanks once again.
martin42
Re: loss of power
« Reply #8 on: 23 April 2012, 15:59:31 »
main dealer for part,no idea on costs either
snipe
Re: loss of power
« Reply #9 on: 23 April 2012, 16:17:05 »
Hi Martin
Main dealer £146.00.fitted inc vat. Sounds reasonable.In your opinion will it cure the problem.
Thasnks once again.
Brikhead
  • West-Mids.
Re: loss of power
« Reply #10 on: 23 April 2012, 23:41:02 »
As far as I can work out the part is around £35...
http://www.vauxhallworldparts.com/vauxhall.php?partnumber=90540188
...very easy to fit, I'd charge a regular customer around £20-£30
The sensor is bolted into the engine block, just below the oil filter housing, may be easier to access from under the vehicle with engine tray removed.
