Rear Wheel Bearing
Started by Entwood, 22 April 2012, 20:57:11
Quote from: RobG on 13 May 2012, 15:28:35
Suggest you re-check diff oil level Nige. The rear end was quite high when I topped it up ;D ;D ::)
Yup .. one of Thursday jobs ....
Check Torques of most of the bolts we did
Hopefully change the 3 "strange" bolts if someone can provide them
Check Diff level
Change centre arm rest
Fit new lock to passenger locker
Tidy boot
Shackeng
Glad to help Nige, and very glad its sorted. And I forgot the cam kit! I'll pick it up later. :y :y :y
Quote from: Entwood on 13 May 2012, 14:14:50
Right :)  The job is jobbed !!!  :y :y :y :y :y :y :y ......
A result!!  :y   :y  :y
Splendid news - well done to all concerned. 8) :y
Has yours ever had the pinion seal replaced?
Quote from: Marks DTM Calib on 14 May 2012, 10:23:09
Think 2Woody? done it at the Hampshire meet Mark http://www.omegaowners.com/forum/index.php?topic=38139.0
see reply #73  ;) should've been OK cos an expert fitted it!  ::) ::)
Quote from: Andy B on 14 May 2012, 10:28:39
But, referring to reply 76, the flange bolt had worked loose IIRC, so something odd was going on back then.
Quote from: Kevin Wood on 14 May 2012, 10:34:51
Why let the truth get in the way of a good story?  ::) ::) ::)
Ok, so the reference was already lost.
That is key as there is only one useable method for seal replacement e.g. the mark and re-fit approach.
The torque method (which is diffcult to do) can only realy be applied when fitting a new bearing.
sassanach
oooh!!! hang on to the old diff  mr entwood,we gotta rip that apart for e shufti. :y
Shackeng
Quote from: Marks DTM Calib on 14 May 2012, 12:17:18
Nige pointed out that 2Woody had to guestimate the setting because of this. :(
