tyre pressure
Started by raywilb, 24 April 2012, 20:50:26
Depends when measuring perhaps? If always on a cold morning having made them all the same the night before...?
I tend, out of laziness to check mine after I get home. A no no, as they should be cold, but I'm looking for oddities. Being aware the pressure will rise with use, but if one is lower, I'll adjust and keep an eye on it after checking for screws and nails.
But for the op, maybe check psi after a run, then when cold, then again after a run and see what psi you have.
But I agree with Entwood, if your constantly adding pressure somethings wrong. Although depends how often your checking...?
