Author Topic: tyre pressure  (Read 5805 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
tyre pressure
« on: 24 April 2012, 20:50:26 »
i dont know why it is, but the front n/s tyre always needs a few lbs of air when i do a weekly check. i.m not kerbing it, the steerings ok, & iv,e even rotated wheels . but its always that wheel . Ideas anybody  :-\
Re: tyre pressure
« Reply #1 on: 24 April 2012, 22:00:03 »
Puncture, valve, or leaking rim.
Take off, put in bath/water butt, leak should be noticible
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: tyre pressure
« Reply #2 on: 24 April 2012, 22:18:09 »
Same here. I've just had four new tyres fitted and the same wheel still loses a few lbs of air so in my case it must be the rim leaking as TB said as the valve and tyre was discarded. Going in this week and hoping the tyre place can put some sealer around the rim.  :-\  Bit of a mystery as the alloys not damaged.
Re: tyre pressure
« Reply #3 on: 24 April 2012, 22:21:39 »
Some fastfits don't clean up the rim properly, relying too much on the sealant.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: tyre pressure
« Reply #4 on: 24 April 2012, 22:25:30 »
Might be worth pulling the tyre off, cleaning the rim with some fine grade paper and lacquaring the wheel before you put the tyre back on
Only way imho  :y
Re: tyre pressure
« Reply #5 on: 24 April 2012, 23:01:09 »
If the front n/s always leaks even after tyre rotation .... just what has that to do with rims/valves/etc ??  :)
If I read the OP correctly ........
My question  to you is .. do you always check the wheels in the same manner ?? Possibly starting with the F/N/S every time, and always using the same garage ??
If so it "might" be that the garage gauge is a tad "sticky" until exercised a couple of times and that is the problem ??
I cannot see how the F/N/S can otherwise be affected on its own...
Re: tyre pressure
« Reply #6 on: 24 April 2012, 23:37:09 »
I read it like that too Nige... Confusing :-\
I can't see any other explanation other than the one you've just described :-\
YZ250
Re: tyre pressure
« Reply #7 on: 24 April 2012, 23:48:09 »
Didn't read it like that until you mentioned it.  :y  OP does appear to say that. At least in my case I know which wheel it is.  ;D
raywilb
    • Citroen C4 Cactus
Re: tyre pressure
« Reply #8 on: 25 April 2012, 00:24:43 »
i have a digital guage plus its always the same n/s tyre  not only on rotation but when iv,e actually changed wheels for another set i have . baffling me
Re: tyre pressure
« Reply #9 on: 25 April 2012, 00:29:19 »
Did you use the same tyres, or a whole new set of wheels & tyres? Have you tried rotating this set just in case you have two that leak and managed to get them on the same corner (unlikely but not that improbable)?
If it's neither of those things then it's got to be aliens. Or someone is letting your tyre down. Or aliens are letting your tyre down ;)
raywilb
    • Citroen C4 Cactus
Re: tyre pressure
« Reply #10 on: 25 April 2012, 17:36:23 »
it must be aliens. in 9yrs , two sets of wheels & 3 sets of tyres its always the front n/s (on a wkly basis) that loses up to 6lbs of pressure. reiterate , not kerbing .& steerings ok. :-\
Re: tyre pressure
« Reply #11 on: 27 April 2012, 08:46:32 »
The only thing I've seen similar to that is on my car, relative to where it's parked up against a garge door at the front and a wall to the left front wheel. After an hour of sunlight the drivers side wheels are warmer, and the pressure goes up .5 to 1 psi. relative to the ambient temp.
Where as the one in the corner by the wall gets no sun, doesn't warm up, and stays stone cold. Some times 2 or 3 psi lower than when tested the day before.
Try nitrogen instead of air...?
Can't explain the range of difference your seeing though. 6psi is too much for that Ime
« Last Edit: 27 April 2012, 08:51:08 by chrisgixer »
Re: tyre pressure
« Reply #12 on: 27 April 2012, 08:55:26 »
Although adding the differences might add up to 6psi.
Is it seasonal? Ie less loss in summer with warmer night temps. ?
Re: tyre pressure
« Reply #13 on: 27 April 2012, 09:05:16 »
I get what you are saying ... but ..... if it was temp related .. when he inflated the "cold" low one it would be overpressure when warm, then drop back down to "correct" once it cooled down  ???
If it is ALWAYS low and gets topped up regularly it must be actually losing air .. and  I see no logical reason ... otherwise it would be the size and pressure of a zeppelin by now !!!
puzzled of wiltshire ......
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: tyre pressure
« Reply #14 on: 27 April 2012, 09:19:50 »
Or the most simple on of all, some bugger is playing games and letting air out  :-\
Page created in 0.022 seconds with 20 queries.
