imob transponder removal
Started by michaelprg, 26 April 2012, 18:39:07
michaelprg
hey all. I need some help, and cant seem to find the info im looking for anywhere!
i need to remove the imobilser transponder off a 2000 omega so its the facelift , is there a special way of taking it off or is it a wack it off!? as i dont want to damage it  :D
Any help will be appreciated :)
The actual transponder (in the key) or the Immobiliser ECU (around Ign)?
michaelprg
Quote from: TheBoy on 26 April 2012, 19:17:09
the unit that surrounds the barrel, sorry should have been more clear :)
michaelprg
Quote from: RobG on 26 April 2012, 20:11:23
Force it, but there`s a risk of it snapping, or remove the barrell
http://www.omegaowners.com/forum/YaBB.pl?num=1213353737
http://www.omegaowners.com/forum/YaBB.pl?num=1225659626
splendid! i did a search but coundt bring up stuff of much use!
But thanks a ton! ill play it safe and take the barrel out :)
Meik
Agemo
Mine came off easily enough, but then I was removing it to replace. It shouldn't break, unless you get mad with it.  :y
