Author Topic: car dies and no error codes stored.  (Read 2908 times)
fakeq
    • b x20xev 96 cd st
« on: 30 April 2012, 22:51:56 »
Evening from the wasted nords.
As my topic sayes the engine stops while driveing, then I stop and and turn the ingnition and car starts idiling fine, as soon i start driving afther a while i feel the enginge looses power and pump the gass more and it goes up in rpm again but wont work all the time and stops again.
This isnt happening all the time and I can run many miles before this happens again. Had some of this problems before and then it was error codes with the cam sensor, so I installed new cam sensor, belt etc.
But have noe codes stored now.  :-[
There was a happening a few weeks ago where the car wouldnt start and there was a rappidly blinking in the engine light so I plugged in the code reader and woila, car starts and no codes stored.  ??? My guess here was that the immobilizer hung, but cant know for shure.
So im at a loss here and would be glad for some pointers where to look, its so fustrating that this problem is hard to find. I could change a part and the problem could stil be there afther weeks.
davethediver
  • Blackburn, Lancs.
Re: car dies and no error codes stored.
« Reply #1 on: 30 April 2012, 22:55:51 »
P.A. Caron de Beaumarchais
fakeq
    • b x20xev 96 cd st
« Reply #2 on: 30 April 2012, 23:09:10 »
Have you had a look here http://www.omegaowners.com/forum/index.php?topic=90509.0
May help :y
Thanks, did this when when i serviced the cam kit, new hoses, oil trapper, new jet breader needle and idler. Cleaned it very thorough.
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
« Reply #3 on: 30 April 2012, 23:37:45 »
i had a cavalier with the same engine in it.x20xev 16v ..new crankshaft sensor sorted it,but i had the same symptoms as you for about 2 months before the engine management light came on and stored a code...hth... :)
fakeq
    • b x20xev 96 cd st
« Reply #4 on: 01 May 2012, 00:04:45 »
Im very found of this engine, incredibly strong. Have 380k mileage now and 200k is in my ownership.  :)
To the problem , I left out that it won't ignite at all after it dies and I have to wait for a while before it starts. So could it be fuel related or the immobiliser playing pranks with me.
I dont think it is the fuel filter but I have a new one, so I could just change it for the luck sake. The fuel pump is humming fine. It dosent cough or anything, its run fine or not running at all.
So it needs to learn the new fault before code is stored?  :P
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #5 on: 01 May 2012, 03:21:35 »
check the crank cable if not fitted back propper cable heats up on the exhaust manifiold and cuts engine out.
Solar charger fitted.
If not Broke dont fix it..
fakeq
    • b x20xev 96 cd st
« Reply #6 on: 01 May 2012, 14:29:39 »
Thanks for the pointer :), the cable was actualy touching the manifoild and not fitted propperly.. But it didnt seem broken or melted in any way. Think i should change the cable?
freecall666
« Reply #7 on: 01 May 2012, 15:14:15 »
melts the wires inside the heat sheild, can be fixed if you cut down the wire heat shield (were the wire was touching manifold), and tape them up then make sure its fixed way from the manifold. :y
« Last Edit: 01 May 2012, 15:16:10 by freecall666 »
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #8 on: 01 May 2012, 16:17:34 »
Tip of the day I reckon.  :y
RIP Paul Lovejoy
« Reply #9 on: 01 May 2012, 21:55:27 »
 ??? ??? :o
