Author Topic: tyre size  (Read 4050 times)
greenman
  • greenock
tyre size
« on: 01 May 2012, 19:18:09 »
Anyone know the correct tyre profile for 18" wheels so that the speedo is accurate?
Martian
Re: tyre size
« Reply #1 on: 01 May 2012, 19:42:41 »
Assuming the standard tyre size for your particular model is 225/55 16, and assuming you are not going to increase the width on the 18" rims, the closest match is a 225/45 18
greenman
  • greenock
Re: tyre size
« Reply #2 on: 02 May 2012, 10:38:44 »
Typical!
I,ve a set of 235.40,s. So how much would the speedo be off if
I fitted these?
Martian
Re: tyre size
« Reply #3 on: 02 May 2012, 10:52:52 »
The speedo will be off by 1.3%, so at an indicated 60mph you will actually be travelling at 59.2mph
i260
  • Newport, South Wales
Re: tyre size
« Reply #4 on: 02 May 2012, 14:36:34 »
Typical!
I fitted these?
I believe that this was the specified size for the 18 inch option from factory though!
225 on an 18 is deffo not right from VX even if it is the nearest match.
If you look at the difference in rolling radius between the 225/55/16 and 235/45/17 they are not exactly close, the 17 being somewhat smaller.
The 225 will offer better handling, particulaly if you are on the usual 7.5 inch aftermarket rim width but on the Irmy 8 inch widths you will be leaving yourself exposed to kerbing - your choice!!
Saab 9-5 Aero 260ps
2woody
  • Northumberland
Re: tyre size
« Reply #5 on: 02 May 2012, 17:20:56 »
ok - so here goes.....
your standard tyre gives a wheel revs per mile of 817 - indeed, this is the standard for Omega A and Omega B
if you're wanting to go to 18" wheels, you have the following options.....
215/40 x 18, giving 811 wrpm ( or 0.7% diffrerence )
235/40 x 18, giving 820 wrpm ( or 0.4% difference )
245/40 x 18, giving 811 wrpm ( or 0.7% difference )
the aforementioned 225/45 yields 804 wrpm, which is 1.6% different - a bit too much really.
my choice would be the 215/40, which will still give you some combat against tramlining and a bit of handling left.
Re: tyre size
« Reply #6 on: 02 May 2012, 20:13:46 »
Cars with 225/55/16 tyres have a different dash (pre 98) or config (post 98) to all other tyre sizes, guess that size is too far out of the standard Omega-A/B spec
cube
  • Leeds
Re: tyre size
« Reply #7 on: 03 May 2012, 22:06:23 »
My 2001 2.2 petrol estate has got 205/50-16 tyres on, not really sure if right or wrong ???  :o
Not due for change for a while so will be sticking with unless completely wrong ???
2.2 petrol GLS estate
Sam Burton
  • St Neots, Cambridgeshire
  • Just Car Mad Really
    • Many
Re: tyre size
« Reply #8 on: 03 May 2012, 22:27:46 »
Not completely Wrong they are just a Smaller tyre Height wise if yours has the Facelift CD wheels on they should be 225/55/R16 but then again you may have a completely different style wheel e.g. early GLS spec wheels with the chrome style centre but im not familiar with that size?
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
cube
  • Leeds
Re: tyre size
« Reply #9 on: 03 May 2012, 22:33:38 »
Thanks Sam  :y, car drives ok with them lol, i'll have to keep them for a while and swap round when i need to. Change the back to 225/55-16 first lol  :D Ps no idea at all which model allow wheels are fitted ????
« Last Edit: 03 May 2012, 22:36:14 by cube »
Zippy2012
  • Worcester uk
    • 99,3.0 MV6 Est Ex Police
Re: tyre size
« Reply #10 on: 03 May 2012, 23:28:34 »
Not compleatly wrong but your speedo will be...
if the standard tyre size should be a 225 55 16 & you have fitted 205 50 16s
at 30mph on speedo you will be doing only 28mph
but at 60mph on speedo you will only be doing 56mph
90mph-84mph
120mph-112mph
Great if you dont want to be caught speeding in the local limits but over time you will put more miles on your car than its actually done  :-\
if the standard size for you car was a 195 65 16 speedo would be out by..
30mph-27 actual
60mph-55 actual
90mph-83 actual
would be worth finding out the standard fitment to your car & soucing a set of replacements soon
i bet the 205 50 16s look tiny in the huge omega wheel arches!???
