Yellow ish side lights
Started by omega3000, 01 May 2012, 21:21:09
Im looking i think at the side light bulbs which look yellow ish when switched on , compared to the bulls eye ones which are blue e white . Any idea what i should replace them with to get a similar effect as the bulls eye ones . Are these bulls eye ones im referring to called projector lights  :-\
Projector style, For the sidelights try white LED`s (6-bulb type)
Quote from: RobG on 01 May 2012, 21:24:48
They just look like candles in the wind compared to the projector's  ::)
martin42
got some led's here mate if you want to try them :y
Quote from: eatmydust on 01 May 2012, 21:29:43
You can`t compare sidelight bulbs whether LED or otherwise to the output of a HID bulb ::)
Quote from: martin42 on 01 May 2012, 21:41:14
Smashing  :y Just noticed there is 2 bulbs in that unit . Will pop over when your in if you like ...guess they are easy enough to replace  :-X
Quote from: RobG on 01 May 2012, 21:46:21
I think LED will improve it a bit  :) must be the original bulbs in it at mo .
LFF64
I have changed mine for the 6LED type they look much better
I have also changed the puddle/door lights and rear number plate and interior lights for LED as I prefer the light colour plus if you have the doors open there is hardly any drain on the battery with the LED  :y
Sam Burton
Just to give everyone a heads up be really careful what colour LED you put in your sidelights and numberplate lights as mine failed on being an incorrect colour :o :-\
i had some cheapy quite brights white with slight blue tinge i've now replaced with just white LEDs but stronger and it Passed so..
Another thing for MOT'rs to fail on... YAY
P.S Sorry to all you good MOT'rs
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
Thanks for the tips folks  ;) Anyone fitted those aftermarket angel eyes , quite expensive about £200 a set but do like these ones .
Thanks to martin42 from here  ;) ,he popped over and fitted some led side lights which make a hell of a difference .
martin42
pauls
Have you got a pic of the new ones fitted
Quote from: pauls on 04 May 2012, 08:51:50
Yeah i will get one loaded up later today  ;)
Quote from: eatmydust on 04 May 2012, 13:29:35
Stupid camera phone  :( cant get a decent picture just yet but will try again later  ;)
