Code Reader...
Started by Webby the Bear, 01 May 2012, 22:43:01
Webby the Bear
Hi, me again  ::) :y
I watch a lot of videos  :D on cars  ::) and engines and in pretty much all the American vids they use this...
http://www.ebay.com/itm/Actron-CP9175-OBDII-Plus-Diagnostic-Code-Scanner-/290594412801?pt=Motors_Car_Truck_Parts_Accessories&hash=item43a8c6d901&vxp=mtr
Will this work on ze mig?
RIP Paul Lovejoy
Quote from: Webby the Bear on 01 May 2012, 22:43:01
Hi, me again  ::) :y
Yep, as many others will also
Webby the Bear
Quote from: RobG on 01 May 2012, 22:44:36
Hi, me again  ::) :y
Cheers Rob. You ever used this? If so would you recommend bearing in mind Bear doesn't have the sheets to pay for a TechII?
RIP Paul Lovejoy
Only the facelift is OBDII if memory serves me, certainly PFL is not, uncertain about MFL.
The cheap computor based code readers ( often referred to as ELM327 ) are not very good .. and require a laptop as well. getting them to communicate can be a right pain.
I bought a "stand alone" one that gets its power from the car and just needs plugging in and turning on. Does the basics but only engine and a little bit of transmission.
There are "cloned" bits of kit out there but discussion of them is verbotten as they mostly breach copyright regulations.
If your car is OBDII they are a very useful piece of kit, but in no way mandatory as for all V6's there is either the paperclip or the pedal trick for reading engine codes.
Webby the Bear
Cheers chaps.
£79. I'd pay that for a useful piece of kit!!!  :y
RIP Paul Lovejoy
Quote from: Webby the Bear on 01 May 2012, 22:58:02
Cheers chaps.
Shop around, seen genuine new for sub £50
Webby the Bear
Quote from: RobG on 01 May 2012, 22:58:58
Cheers chaps.
Even better! Many thanks!  :y :y :y
RIP Paul Lovejoy
PM incoming to the bear. ;)
An OBDII reader will only work on 3.2, 2.6 and 2.2 Omegas. :-\
D
Albs, do you have any info re these readers? I am looking around for a reasonable one as well.
D
omegod
