Author Topic: Front pads and wear sensors  (Read 3457 times)
jonathanh
  • coventry
« on: 05 May 2012, 15:02:21 »
Anyone know what the current TC price is for these?
Re: Front pads and wear sensors
« Reply #1 on: 05 May 2012, 17:21:29 »
Pads..........9192124 £26.35 £22.40 £15.00
Sensors.........90495144 £10.60 £9.55 £8.00
jonathanh
  • coventry
« Reply #2 on: 05 May 2012, 20:14:54 »
Many thanks much appreciated!  I'll pm andyc
Apologies to the admins if this was in the wrong place
the alarming man
  • medway kent
    • disco V8
« Reply #3 on: 05 May 2012, 21:48:24 »
i brought front pads and a wear sensor last week from my local stealers....it come to less than £ 30....but it started at £ 50 when i rang ton ask if in stock.... :y
« Reply #4 on: 06 May 2012, 10:09:40 »
The pads are quite heavy, not sure if that will make postage expensive. Sure andyc will happily tell you :y
« Reply #5 on: 06 May 2012, 12:49:50 »
Postage on the last set of fronts & rears I got from Andy was a fiver, IIRC  :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #6 on: 06 May 2012, 16:03:14 »
Hi guys, my pad warning came on again today..... are the sensors only on the front pads????
that part number thrat rob quoted is presumably what i need... and both sides need doing?
cheers chaps  :y
RIP Paul Lovejoy
« Reply #7 on: 06 May 2012, 16:06:58 »
cheers chaps  :y
Yep. You`ve probably got sensors on both fronts being early F/L. If fitting new, just fit to one side and bridge the terminals of the other connector with a bent paperclip or similar and tape up
Webby the Bear
  • Northampton
« Reply #8 on: 06 May 2012, 16:17:09 »
cheers chaps  :y
cheers rob.
is that cos the £8 TC cost you quoted was for just one side and you only need one side cos the pads will be the same level on the other side? if that makes sense  :y
RIP Paul Lovejoy
« Reply #9 on: 06 May 2012, 16:18:05 »
cheers chaps  :y
cheers rob.
Just about sums it up Steve
Webby the Bear
  • Northampton
« Reply #10 on: 06 May 2012, 16:19:37 »
cheers chaps  :y
cheers rob.
Cheers Roberto Di Broteo  :y :y :y :y
RIP Paul Lovejoy
