Author Topic: 2.2 engine... wheres my oil??  (Read 8112 times)
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
« on: 12 May 2012, 13:55:21 »
Ok I have  2.2 with 107k on the clock... only had it about a month ish so dont know history... did oil and filter change about 500 miles ago and today had the : check oil level: warning on the display... on checking dip stick there was sod all on it.. No leaks to be seen on top or bottom... cam cover gasket is leaking but not to the extent of losing that much oil...  dont have any water in oil ect... Any ideas people??? :(
martin42
Re: 2.2 engine... wheres my oil??
« Reply #1 on: 12 May 2012, 13:56:37 »
cam cover gasket,it might not look like a big leak but it can be,replace asap :y
vauxsull
    • 3.0 Elite
« Reply #2 on: 12 May 2012, 14:05:43 »
back two plug wells are damp but not swimming in oil... if it was leaking externally surely id see/ smell oil??
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
« Reply #3 on: 12 May 2012, 15:11:17 »
if no signs of oil dripping underneath at the back of the engine,and the plug wells are ok,the only other thing is that the engines burning it...you have no oil patches once its been parked up overnight..?how much oil did you put in when you last serviced it..?
« Last Edit: 12 May 2012, 15:12:50 by ndmv6 »
vauxsull
    • 3.0 Elite
« Reply #4 on: 12 May 2012, 15:12:44 »
nope not even a dribble... no smoke billowing out of exhaust either.. surely not burning with just over 100k on clock?
vauxsull
    • 3.0 Elite
« Reply #5 on: 12 May 2012, 15:16:39 »
cant remember how much i put in now but all was up to max after changing it and re checked next day. what is the engine oil capcity for the 2.2 anyway?
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
« Reply #6 on: 12 May 2012, 15:17:44 »
i use GM 10/40 oil in mine,change it every 6 months,never lost a drop since i changed the cam covers(they were leaking badly though at the back) if no leaks,ide just top it up  :)
vauxsull
    • 3.0 Elite
« Reply #7 on: 12 May 2012, 15:19:30 »
shouldnt have to put a ltr in after 500 miles though??
« Reply #8 on: 12 May 2012, 15:29:28 »
Should take app. 4.5ltrs on a change
davethediver
  • Blackburn, Lancs.
« Reply #9 on: 12 May 2012, 15:30:57 »
Mines starting to use a bit now but im at 135K on mine ???
P.A. Caron de Beaumarchais
davethediver
  • Blackburn, Lancs.
« Reply #10 on: 12 May 2012, 15:32:07 »
So a 5ltr container gives you enough for the oil change and a top up after a few miles ;D ;D
Sam Burton
  • St Neots, Cambridgeshire
  • Just Car Mad Really
    • Many
« Reply #11 on: 12 May 2012, 15:54:11 »
Stupid question when you oil and filtered it did you redip after changing the oil filter and running it up ?
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
vauxsull
    • 3.0 Elite
« Reply #12 on: 12 May 2012, 16:07:24 »
yes i did Sam..... im sure i put more than 4.5 ltrs in it on the oil change??
« Reply #13 on: 13 May 2012, 11:38:19 »
If the oil level is dropping, and its not leaking externally, then clearly it has to be exiting through the combustion chamber.
The Check Oil Level warning should come on when cruising oil is approx halfway done the dipstick.
    • E250 Est / Elroq
« Reply #14 on: 13 May 2012, 11:48:34 »
Think the oil is the least of its worries now  :-X
