Author Topic: low tickover  (Read 2436 times)
alan_rose
  • birmingham
low tickover
« on: 13 May 2012, 09:58:09 »
hi all i was wondering if anybody can help, i did the paper clip test to my w reg 2litre 16v omega and the code 0340 came up.
the tickover is very low and it keeps trying to cut out when the engine is warm
cheers
alan
  • Auckland
    • Mazda MPV
Re: low tickover
« Reply #1 on: 13 May 2012, 10:15:00 »
The list of error codes here http://www.omegaowners.com/forum/index.php?topic=90583.0
lists it as
P0340       Camshaft Sensor Incorrect Signal
The 4 cylinder engines do seem to be prone to camshaft sensor failure. Replace it with a genuine Vauxhall/Opel sensor. The pattern ones don't seem to last 5 minutes.
The idle speed should be quite low (about 650rpm IIRC for a 4 cylinder). Fix the misfire and it will idle smoothly :y
Re: low tickover
« Reply #2 on: 13 May 2012, 10:16:22 »
..... and the code 0340 came up.
cheers
alan
http://www.omegaowners.com/forum/index.php?topic=90583.0 ''cam shaft sensor incorrect''
 Erratic tickover ..... Is there an idle control valve  on the car? Could be that that's sticking :-\ Induction air leaks?
alan_rose
  • birmingham
Re: low tickover
« Reply #3 on: 13 May 2012, 17:57:08 »
thanks all i have got hold of a idle motor and will fit it later tonight, if that dont work its the camshaft sensor.
cheers
alan
Re: low tickover
« Reply #4 on: 13 May 2012, 18:12:50 »
cheers
alan
If it does work you`ve still got a fault code for the cam sensor
alan_rose
  • birmingham
Re: low tickover
« Reply #5 on: 14 May 2012, 18:27:06 »
fitted the idle valve drove to work everything fine, come home everytime i stopped it cut out, did the paper clip test again and now code 0340 and 0100 comes up mass air sensor voltage high what does that mean, i would be greatful of any advice, i will be changing the came sensor this weekend
cheers
alan
Re: low tickover
« Reply #6 on: 14 May 2012, 18:44:35 »
cheers
alan
Change the cam sensor, (genuine only)
Abiton
Re: low tickover
« Reply #7 on: 14 May 2012, 19:29:30 »
Agree with Rob, both codes will probably be caused by the failing/failed cam sensor.  Buy a genuine one, from a Vauxhall dealership (none of the online spares shops sell genuine ones, though they try hard to give that impression).
PM or phone member andyc on here for the best price for a genuine one, he's a very helpful parts geezer at just such a Vx dealership.
If after you've got rid of the codes, you still have trouble with cutting out, it'll be in your interests to read and act upon this thread: http://www.omegaowners.com/forum/index.php?topic=90586.0
Now that you have a new idle valve you won't need to clean that out, but the small breather jet referred to in Grumpy's guide is also very important on the 2.0s.
Good luck with it.
alan_rose
  • birmingham
Re: low tickover
« Reply #8 on: 14 May 2012, 20:38:23 »
thanks for that lads, i will take your advice
alan_rose
  • birmingham
Re: low tickover
« Reply #9 on: 19 May 2012, 11:16:32 »
replaced the cam sensor today (vauxhall one £60) started the car allowed it to reach temp, what a difference all better now.
the idle valve which i got from carspares lasted about 8 miles, so replaced it with the old one.
thanks to everyone for there help
cheers
alan
Re: low tickover
« Reply #10 on: 19 May 2012, 11:19:11 »
cheers
alan
Excellent :y
