Author Topic: rear blind  (Read 3419 times)
scorpius92
  • colchester
    • 52. 2.6 elite salon
rear blind
« on: 14 May 2012, 20:35:50 »
hi guys just got a rear blind ,parcel shelf and switch in a job lot of stuff. i have a 2002 elite and been told by twigglet that the wiring is already in place. i`ve manged to fit the switch that lights up with the dash lights but the rear blind seems to be missing some wiring. ive been told that the connections by the rear strut which ive found but can i get the wiring between blind and loom.
« Last Edit: 14 May 2012, 20:39:36 by scorpius92 »
Re: rear blind
« Reply #1 on: 14 May 2012, 20:38:09 »
hi guys just got a rear blind ,parcel shelf and switch in a job lot of stuff. i have a 2002 elite and been told by twigglet that the wiring is already in place. i`ve manged to fit the switch that lights up with the dash lights but the rear blind seems to be missing some wiring. ive been told that the connection is by the rear strut which ive found but can i get the wiring between blind and loom.
Stupid question.................is the blind motor attached to blind body underneath the shelf
Re: rear blind
« Reply #2 on: 14 May 2012, 20:41:18 »
You need the bit of loom to blind. One of the breakers here might help. As you say there's a bit if loom missing. Runs from car loom plug to control box by the motor.
scorpius92
  • colchester
Re: rear blind
« Reply #3 on: 14 May 2012, 20:41:33 »
yes mate its all there. i was tring to upload a picture. it looks as thou theres a place to plug in to it next to the main wiring to from the motor to the blind
scorpius92
  • colchester
Re: rear blind
« Reply #4 on: 14 May 2012, 20:42:32 »
Cheers guys I'll have a look about
« Last Edit: 14 May 2012, 20:48:14 by scorpius92 »
Re: rear blind
« Reply #5 on: 14 May 2012, 20:47:34 »
Sounds like you`re missing the loom to the boot connector, top plug & wiring in this pic
Re: rear blind
« Reply #6 on: 14 May 2012, 20:49:24 »
Haven`t you got one on your knackered blind Chris :-\
Re: rear blind
« Reply #7 on: 14 May 2012, 20:53:33 »
If you get stuck I can supply you with the connector & short loom to plug into boot connector and if you look at my pic you can see what wires go where into the motor module and you can make up a 3-wire loom
Re: rear blind
« Reply #8 on: 14 May 2012, 22:28:06 »
Is it the loom you have has the earlier plug which doesn't fit the later plug on the facelift?
scorpius92
  • colchester
Re: rear blind
« Reply #9 on: 15 May 2012, 12:47:15 »
Yeah looking a that picture its the red,blue and brown cable I'm missing. It's I presume goes to the main loom near the rear strut.
twiglet
  • Norwich, Norfolk
Re: rear blind
« Reply #10 on: 15 May 2012, 12:58:48 »
Yes it does.  I would have expected this section of loom to come with the blind and shelf.  Did you remove it from the car yourself, in which case it might be worth popping back and getting the bit you need.
Re: rear blind
« Reply #11 on: 15 May 2012, 13:14:49 »
Easy enough to fabricate a loom if all else fails
twiglet
  • Norwich, Norfolk
Re: rear blind
« Reply #12 on: 15 May 2012, 13:16:05 »
Agreed.  But would be nice to have the original wiring if possible.  :y
Re: rear blind
« Reply #13 on: 15 May 2012, 13:17:36 »
Agreed :D
scorpius92
  • colchester
Re: rear blind
« Reply #14 on: 15 May 2012, 15:53:33 »
No I didn't strip the car. I was after some leather seats when I turned up to collect the guy said help yourself any thing that  fits a omega I could have so I loaded up.  The parcel shelf and blind was amongst all the other stuff
