Author Topic: cruise control actuator.  (Read 1883 times)
bluebuss
  • france
« on: 15 May 2012, 09:27:55 »
hi there again, need some more help. are these controllers all different part numbers?
trying to source one from ebay.... loads about but not to sure if they are all compatable..
dumb question maybe...but then we dont know it all do we....
help please, thank you, :-\
Re: cruise control actuator.
« Reply #1 on: 15 May 2012, 10:24:09 »
Actuators are the same. Bowden cables have two different lengths dependent on whether short or long plenum fitted on V6
bluebuss
  • france
« Reply #2 on: 15 May 2012, 10:29:48 »
thankyou, im going to fit it on my 2,0l. do you think a long or short cable should do??
hotel21
  • The Kingdom of Fife
« Reply #3 on: 15 May 2012, 13:00:45 »
Would suggest that the first thing to check is that there actually is wiring on the strut top to connect it to as I recall reading on here somewhere that the 2 litres were not always fitting with the required wiring for some reason.
« Reply #4 on: 15 May 2012, 13:13:26 »
Only the CDX spec had it fitted. If OP`s is a lower spec will also need the bracket on the throttle body (hens teeth)
bluebuss
  • france
« Reply #5 on: 15 May 2012, 16:51:30 »
thanks, its got the bracket on the throttle body with the hole for the cable and the wiring on the strut top....
bluebuss
  • france
« Reply #6 on: 15 May 2012, 16:57:35 »
 :y it is a vauxhall not an opel...its now registered in france :y
