Author Topic: Low field of vision  (Read 2104 times)
KJO
  • Cork
Low field of vision
« on: 18 May 2012, 12:11:38 »
Please find attached a picture of the control unit for levelling the headlights. It is fixed in position, there is however about 15mm of movement on the arm. If this looks ok can anyone suggest why I'm getting the message "low field of vision". The lights are definitely too low as I have had them checked.
Zippy2012
  • Worcester uk
    • 99,3.0 MV6 Est Ex Police
Re: Low field of vision
« Reply #1 on: 18 May 2012, 12:13:21 »
No pic attatched....???
KJO
  • Cork
« Reply #2 on: 18 May 2012, 12:19:37 »
The next question is as I failed to attach a picture is how to attach a picture to a post.
the alarming man
  • medway kent
    • disco V8
« Reply #3 on: 18 May 2012, 12:24:57 »
KJO
  • Cork
« Reply #4 on: 18 May 2012, 12:34:28 »
Sorry here is the picture.
« Reply #5 on: 18 May 2012, 12:44:16 »
Do both level motors work? Can you hear them operating when lights are switched on? Have you checked the rear sensor on the trailing arm? Bottom left in this pic
KJO
  • Cork
« Reply #6 on: 18 May 2012, 12:50:14 »
Yes I checked the trailing arm sensor & it was ok. What I didn't say was that the fault is intermittent. However it spends more time not working than it does working. It can work off & on whilst on a journey.
Zippy2012
  • Worcester uk
« Reply #7 on: 18 May 2012, 14:38:21 »
Are your headlight adjusters inside headlight ok?? if you pop off the mainbeam rubber boot & VERY CARFULLY make sure the headlight internals are not broken??? by trying to move the inner lense dont pull on the bulb or its wires!!!
because 1 of mine is busted.. when it does its headlight updown check when you turn lights on, the n/s sometimes doesnt move or will catch & pull it upwards or it slips & drops down because the adjuster is broken giving me 1 of 3 things,
headlight looking for the pigions in trees..
headlight correct..
headlight trying to look down the drains..
maybe worth a check???
« Reply #8 on: 18 May 2012, 15:31:13 »
headlight correct..
Dipped
Zippy2012
  • Worcester uk
« Reply #9 on: 18 May 2012, 15:37:46 »
either.. if its on xenons you calnt remove the cover without undoing them anoying torx bits!! so thort the main h7 bulb cover be easyer to check it....???
is that pic posted of positions a saloon or estate?? i wondered because my fuel filter is wedged above the diff & is well orquard to try & change... or is it ment to sit in possition pictured??? who evers car that is could do with a rear box u can see a hole in the pipes  :(
