Author Topic: Self Levelling Fun  (Read 3619 times)
Self Levelling Fun
« on: 19 May 2012, 18:14:01 »
Been changing the Estate SL shocks on MotherT's Elite today, tad different from Saloon I found. (i've taken some pictures to add to the guide)
I've been wondering if GM have made changes to the mounting & shock? First off removing the old one was a b@starrrrd, they were rusted in solid. Breaker bar + foot + tons of swearing got them off, just.
So removing the old shock, looked like this:
Now that metal part above the washer on the other shock, fell straight off. This required hammer + screwdrive + more swearing to get off.
Now with the saloon, I don't remember a metal washer on the outside of the car?
Way I refitted was this:
Now the old big fat washer, had metal internals. The new ones (GM sourced) were plastic inside.
I'm sure I asked for Estate shocks, dealer I use always excellent. Have I accidently got saloon shocks? (part number i have is 72119085) Is GM cutting costs again with parts? (plastic not metal)
All refitted everything appears ok. I just caught the SL pump fire up briefly, can tech2 test/activate SL pump?
Finally, removing old shock, I found glue in the pipework of the nearside one. Looks like someone on purpose before our ownership blocked it up  ??? - Air pipe was on & clipped in place. Although no air escaped when removed on either shock.
I have heard the SL pump activate before, wondering what affect that would have had  :-\
« Last Edit: 19 May 2012, 18:16:57 by tunnie »
Re: Self Levelling Fun
« Reply #1 on: 19 May 2012, 18:27:40 »
Activate pump yourself, just pop lower socket off of sensor and lift the arm
« Reply #2 on: 19 May 2012, 18:30:00 »
Good point, me did not think of that. Guess that will just raise one side?
« Reply #3 on: 19 May 2012, 18:31:26 »
Only if the other side is donald ;D ;D
« Reply #4 on: 19 May 2012, 18:35:43 »
Both shocks are new, looking at the weather I cannot be bothered now, but will try that tomorrow  :y
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #5 on: 19 May 2012, 18:44:23 »
Correct part number for TC estate SL shocks.  :y
As Rob said with the sensor arm test.  :y
« Reply #6 on: 19 May 2012, 18:45:51 »
Many thanks for checking part number  :y
Will test, so that suggests the mounts/rubbers have been under the cost cutting GM knife again  :(
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #7 on: 19 May 2012, 18:47:24 »
Did you remove the metal sleeve on the top of the old shocks and put them on the new ones.
When I replaced mine about 12 months ago, as they were not included with the shock absorbers, I had to remove the old ones which were well rusted on and were a right !**$%^**(  !^&***)(&*% ***^%**() to remove.  ::) ::) ::)
« Reply #8 on: 19 May 2012, 18:50:10 »
Yes these were too & no I did not re-fit them. D'oh. Thing is on the offside one, there was no trace of it  :-\
Rods2
« Reply #9 on: 19 May 2012, 19:00:51 »
You should be able to sort that by taking the top apart, so you don't have the hassle of removing them from the bottom. I smeared the top and bottom joints with Copper Ease so if I need to take them off in the future, hopefully it will be a bit easier.  :y
Looking at the size of the plastic hole on the top rubber, the top of the shock absorber will float around without the sleeve on.  :o :o :o
I don't know how this will affect the cars handling or the wear implications of the plastic moving against the sharpish edges of the top thread.  :(
« Reply #10 on: 19 May 2012, 19:03:56 »
The new rubber washers looked incompatible with that metal sleeve thing  :-\
Rods2
« Reply #11 on: 19 May 2012, 19:11:23 »
They may have changed the design since I did mine. Might be worth asking Andy C as, as far as I'm aware, they update the spares exploded diagrams as parts are modified.
I looked through the pictures I took while doing the job and unfortunately, I didn't take any of the new one with the top parts on before reassembly.  :-\
YZ250
« Reply #12 on: 19 May 2012, 19:23:31 »
Don't know if this is any good to you Tunnie. Shamelessly poached from the below link. Open link for part numbers. :y http://opeloem.com/opel/omega_b_1994_2003/rear_axle_and_suspension/rear_suspension/rear_shock_absorbers_contd__1.html
As Rods2 said, they may have changed.
Opel, Omega-b 1994-2003, Rear axle and suspension, Rear suspension, Rear Shock Absorbers (Contd.)
Regards
Alan
« Reply #13 on: 19 May 2012, 19:27:06 »
Regards
Alan
Thanks Alan  :y
I appear to be missing 6. The spacer  :-\
Never found this on the saloon, thinking about it that metal spacer was inside old rubber washer. But these new ones appeared to have a built in plastic spacer  :-\
« Reply #14 on: 19 May 2012, 19:28:43 »
Although thinking about it some more, it did still move a bit. Wonder what affect not having that will do  :-\
