Author Topic: 2.5 v6 engine problem  (Read 1397 times)
Chaarlis
  • Latvia
    • V6
« on: 19 May 2012, 18:18:48 »
Hello...
Been searching the forum for almost 2h ...for my problem... havent found the solution yet :(
Maybe you guys can help...
after rough driving... i discovered that engine is working wrong... when pushing throttle it feels like engine is working only on 5 or 3 cylinders ... there are massive vibrations coming from engine.... big drop of power.... when not pushing the throttle revs drops to 500 and rising again and dropping till it stops
also my exhaust system was dead and there was only a very small hole for smoke to come out <--- that has been fixed but problem remains..
sry for my bad english...
pauls
  • By the sea minehead
    • Bmw x3
Re: 2.5 v6 engine problem
« Reply #1 on: 19 May 2012, 18:41:39 »
Hello and wecome. If you go to the maintance section and search for pedal trick. Read and  post up codes somebody will be along to help :y
« Reply #2 on: 19 May 2012, 18:43:10 »
First things first, remove the HT leads and inspect the spark plugs  :y
I have a feeling you will find oil  :y
Chaarlis
  • Latvia
    • V6
« Reply #3 on: 19 May 2012, 19:31:29 »
Hmmm.. i will try the pedal trick or the paperclip trick.....
il try that too..
i was reading about thing called knock sensor...that its failure can couse power drop or something....
maybe some other sensors are at fault....
but il try to get some codes :) thanks
« Reply #4 on: 19 May 2012, 19:33:20 »
Start with basics first, check plugs. Then move onto other things  :y
