Author Topic: Help Air con  (Read 1846 times)
rob in gib
  • Plymouth
    • Jaguar S type 3.0
Help Air con
« on: 21 May 2012, 11:14:56 »
 Hi All
My Air con has stopped working any help/advise will be welcome.
At first i thought it would need a re gas, but whilst removing the dreaded faulty power sounder today i thought i would do some checks.
The pollen filter is ok fairly recent and cleanish.
Done the a/c reset and checked all controls on panel, all seem ok.
But when i switch between eco and full auto not noticing any drop in revs.
Checked to see if i could determin wether the a/c pump clutch is working and i DONT think it is.
Q. Should the front outer part of the pump turn when clucth is engaged (mine is not turning at all  >:()
Could this be an easy electrical fix (a broken wire or a fuse) fingers crossed
I will add that i am hoping for something easy at the mo as still recovering from my knee operation and cannot kneel down or move to much  :(
Thanks in advance
Rob
Just chilling in the sun. I wish back in the rain like everybody else
Re: Help Air con
« Reply #1 on: 21 May 2012, 11:33:40 »
There's a low pressure switch in the a/c which needs gas in the system to switch it. Yes, the centre part of the compressor should spin when the a/c is on & not  spin when off or ECO selected.  :y :y
You can apply 12volts to the compressor manually to briefly test it, but I've never needed to so don't know how.  ::)
Re: Help Air con
« Reply #2 on: 21 May 2012, 11:36:25 »
You can apply 12volts to the compressor manually to briefly test it, but I've never needed to so don't know how::)
Just unplug the connector, whack 12V on it, seemples :D
rob in gib
  • Plymouth
    • Jaguar S type 3.0
Re: Help Air con
« Reply #3 on: 21 May 2012, 11:50:46 »
Thanks for the quick replies guys but no pics Rob G i am dissapointed ROFL
I will start with a re gas which i can get done for just a few beers.
Hopefully will be done tomorrow will update soon
Cheers
Rob
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: Help Air con
« Reply #4 on: 21 May 2012, 13:01:46 »
>looks at username<
>does doubletake<
Re: Help Air con
« Reply #5 on: 21 May 2012, 21:57:59 »
If clutch is ok you will hear it engage with a loudish clonk - if alls quiet clutch is seized  :(
