Author Topic: 2.2 CD Auto gearbox problem  (Read 4154 times)
Seanie OD
  • Birmingham
    • Omega 2.2 CD auto
« on: 22 May 2012, 17:50:12 »
Hi all, first time posting on the site, so I hope I do it right.
I bought an 02 plate 2.2 CD Auto the other day and while driving thought the gearbox was clunky when changing both up and down gear. Wasn't sure and was going to get around to posting on the site that very question.
Anyway, today while driving along, going up a small hill I felt what I can only describe as a gear slip (as if a manual popping into neutral). I immediately noticed that the little car warning light with the spanner in it had come on and the car had gone into limp mode. I continued driving for about 10miles to get to where I was going, but as I was nearly there I noticed that it was revving at times then jerking into gear. It got to the point where it just wasnt selecting any gear and just revving like a car in neutral.
I obviously stopped at this point, after I had finished rolling as far as I could to a safe place. I turned off the engine and restarted it to see if that might solve anything. To my surprise it got rid of the warning light but the engine was just revving no matter what gear was selected. I tried moving it through all the gears quickly a few times, when suddenly it clunked as if a gear was selected and it seemed fine again. I then drove the 4 miles further home without a hiccup.
Any ideas on the possible problems please? The car has only got 60K on the clock, but was used to tow caravans (how often I don't know), so not sure if that would cause a great deal of excess wear.
Many thanks
Re: 2.2 CD Auto gearbox problem
« Reply #1 on: 22 May 2012, 17:52:34 »
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
« Reply #2 on: 22 May 2012, 17:53:50 »
first thing is to check gearbox atf level,and colour...should be clean red.having a caravan on the back will have probably burnt the atf  out...there is a guide on hereof how to check it... :)
« Reply #3 on: 22 May 2012, 17:56:22 »
Yep, I just posted it ::) :D
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
« Reply #4 on: 22 May 2012, 17:57:53 »
must type quicker, ;D
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #5 on: 22 May 2012, 18:00:56 »
Also need the codes read if the spanner light came on.
Whereabouts in Birmingham are you?
I like red cars
Seanie OD
  • Birmingham
    • Omega 2.2 CD auto
« Reply #6 on: 22 May 2012, 18:18:39 »
Thanks folks, I'll give it a check and let you know.
Auto Addict:- The light went out when I restarted it, so will it still have codes? I'm in South West Birmingham (Northfield).
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #7 on: 22 May 2012, 18:22:07 »
this sort of fault coming thick and fast
bet the code is
P0730 - Gear Ratio Incorrect
 (08) - Not present
« Reply #8 on: 22 May 2012, 18:28:40 »
Yep, stored in the ECU :)
Seanie OD
  • Birmingham
    • Omega 2.2 CD auto
« Reply #9 on: 22 May 2012, 18:30:47 »
bet the code is
 (08) - Not present
How do I check for fault codes? Or is there a section here which will tell me?
Steve B
  • Leicestershire
« Reply #10 on: 22 May 2012, 18:41:34 »
you need a code reader for the 2.2 ..dont think they work with pedal trick :-\
http://www.omegaowners.com/forum/index.php?topic=90581.0
« Last Edit: 22 May 2012, 18:43:44 by bigtimecube »
bigted
  • glasgow
    • 98 omega v6 elite
« Reply #11 on: 22 May 2012, 19:02:30 »
just tried LUCAS TRANSMISSION ADDITIVE from ebay for similar faults has worked for me unbelievable stuff ..
davethediver
  • Blackburn, Lancs.
« Reply #12 on: 23 May 2012, 00:44:44 »
As much as that may help  ::) or may not ::)  :-X a read of the codes stored will give a more definate answer of what the car wasn't happy with :y
P.A. Caron de Beaumarchais
Seanie OD
  • Birmingham
    • Omega 2.2 CD auto
« Reply #13 on: 23 May 2012, 12:08:07 »
Tried the pedal trick and it didn't work. I will have to get someone with a code reader to have a look.
Its a bit of a game to try and check the ATF after reading the link. As I havent got the equipment needed, is it worth getting the fluid changed regardless to be on the safe side?
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #14 on: 23 May 2012, 20:43:19 »
i would try to get the codes read first as it could be a  waste of money, but checking the the fluid level would not hurt hth ;)
« Last Edit: 23 May 2012, 20:45:49 by noel »
