Zafira help
Started by blackviper90210, 23 May 2012, 16:33:52
blackviper90210
Out with SWMBO in her Zafira 03 plate, 1.8 Auto.
After shopping she started it back up and the spanner light and traction lights are staying on. The gearbox is in limp mode, although changes up if you use it manually.
Using my code reader, the only one I can see, if I've got it right, is U2106.
Any ideas please?
TIA :y
AKA - Mr Bracket
Quote from: blackviper90210 on 23 May 2012, 16:33:52
.... Using my code reader,  ......
Does the pedal trick work on your car?  :-\ I know it will on some, & the code appears on the odometer display MarksDTM is the man to ask.  :y
blackviper90210
Not tried the pedal trick yet. Just about to go to work now, so used the reader I had, for the first time ::)
If I can, I'll try the pedal trick tonight and post the results.
I read that you depress the accelerator & brake at the same time, then turn the ignition on.... is that right?
AKA - Mr Bracket
Quote from: blackviper90210 on 23 May 2012, 16:58:52....
Correct.  :y :y
U2106 CAN-BUS no Communication with TCM B-05
Whatever that means ;D ;D
blackviper90210
It appears that SWMBO's zafira doesn't like  the pedal trick  ??? ???
Any suggestions on what to do next or what my options are please? :(
AKA - Mr Bracket
henryd
Are any of the lads with Tech2 near you?
other rides
No comms with autobox fault code, is it stil doing it?
Are the selector lights working ok?
blackviper90210
Hi Mark,
We've not used the car because of the fault.  Just been out to it now and the car with the spanner light has now gone out, but the ESP light is still lit.
Just driven round the block and the gearbox is now working fine???
Just read up about the ESP and this can be turned on & off, so just gone out to see if I can turn it back on, but the light has now gone out too??
This is the first time this has happend and hopefully the last time!
Only guessing, but could this be caused by dirty connections/loose connection?
Thanks for your time Mark :y
AKA - Mr Bracket
Poorly seated fuse possibly, maybe a loose connector (there not known for electrical issues)
blackviper90210
Thanks Mark. I'll have to look up her car as I don't know anything about the zafira. Cheers again!
AKA - Mr Bracket
