Author Topic: Fitting aftermarket radio  (Read 4322 times)
roberts_1409
  • Lincoln
    • Vectra and Omega
« on: 24 May 2012, 21:14:24 »
Hi all. I'm attempting to fit an aftermarket radio to my Omega B, but can't get it in cuz of all the bl00dy wires and plugs in the way.
Is it actually possible, or do any adjustments have to be made?
Cheers
Craig
Re: Fitting aftermarket radio
« Reply #1 on: 24 May 2012, 21:35:18 »
Yes it can be done, is yours a facelift? Assuming not as it's quite tight around radio on ore facelifts. If you have an Elite & Bose, you need to rip it all out! Speakers, amp everything.
roberts_1409
  • Lincoln
    • Vectra and Omega
« Reply #2 on: 24 May 2012, 21:36:49 »
Mini face lift  :-\
« Reply #3 on: 24 May 2012, 21:44:04 »
Mini face lift  :-\
What radio is already fitted?
roberts_1409
  • Lincoln
    • Vectra and Omega
« Reply #4 on: 24 May 2012, 21:45:28 »
CCRT700
« Reply #5 on: 24 May 2012, 21:46:30 »
roberts_1409
  • Lincoln
    • Vectra and Omega
« Reply #6 on: 24 May 2012, 21:50:26 »
Doesn't have bose on it
« Reply #7 on: 24 May 2012, 21:51:11 »
Is your car an Elite
roberts_1409
  • Lincoln
    • Vectra and Omega
« Reply #8 on: 24 May 2012, 21:55:14 »
No, its a CDX
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
« Reply #9 on: 24 May 2012, 22:51:13 »
I think only certain units work with the information display.
Work is the curse of the drinking classes (Oscar Wilde)
roberts_1409
  • Lincoln
    • Vectra and Omega
« Reply #10 on: 24 May 2012, 23:37:27 »
The stations don't come up on the display, but I'm really not fussed about that, has them on the radio anyway so thats not a problem.
It works fine, had it all plugged up and everything.
Just cant get it all the way in the hole with all the wires and plugs in the way.
Anything behind there that needs cutting to make more room??
« Reply #11 on: 24 May 2012, 23:52:45 »
Nothing to cut. You just have to be methodical about where all the connectors and loom will sit, and not just try to ram it in (which usually ends in tears at bedtime)
roberts_1409
  • Lincoln
    • Vectra and Omega
« Reply #12 on: 24 May 2012, 23:59:17 »
Did end up very stressed. Tried putting the plugs behind and up behind part of the dash.
I'll give it another go tomorrow when I have some light
Cheers
  • Auckland
    • Mazda MPV
« Reply #13 on: 25 May 2012, 18:13:47 »
On my pre-facelift I had the glovebox and instrument cluster out (to pull a DAB aerial wire through & to fit a Nokia handsfree kit).
With the extra access it was possible to ease the chunky iso adapters into odd spaces as I pushed the head unit in.
It IS possible but I find fitting the B*bolt easy by comparison ::)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #14 on: 25 May 2012, 19:20:41 »
Having just done this, I'm glad I am not proposing to fit another wireless! :y
