Author Topic: A bit shaky on start-up...  (Read 1050 times)
llewellyn237
  • Teesside
    • 52 2.2 CD Auto
« on: 26 May 2012, 09:00:02 »
When firing up my 2.2 auto on a morning she judders and shakes a bit, only for a few seconds then all is good.
Any ideas on the cause before it gets worse or turns into something serious?
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: A bit shaky on start-up...
« Reply #1 on: 26 May 2012, 11:32:07 »
try cleaning the spark plugs, looking at them before cleaning should help, check and see what colour they are. also could be water/oil in plug wells check and clean out.
Solar charger fitted.
If not Broke dont fix it..
  • Auckland
    • Mazda MPV
« Reply #2 on: 26 May 2012, 16:46:34 »
Check the plugs and coil pack.
Oil or water around the plugs indicates a leaking camcover (oil) or bonnet seal (water)
If you take the plugs out and just one of the plugs looks as though it has been steam cleaned that would indicate a failing head gasket.
What you don't say is whether this is a recent problem. Cold engines always run a little roughly during warm up while the ECU is chucking extra fuel in. The difficult part is knowing what feels 'normal'.
Page created in 0.008 seconds with 16 queries.
