Author Topic: air con not cold  (Read 4481 times)
Bob G
  • Gloucester
air con not cold
« on: 27 May 2012, 16:26:11 »
Using air con today and noticed it is not very cold, looking under bonnet all seems ok so any suggestions?
2.0L auto X reg
Re: air con not cold
« Reply #1 on: 27 May 2012, 16:27:44 »
2.0L auto X reg
Omega A/C is never "ice-cold". Low on gas possibly
Bob G
  • Gloucester
« Reply #2 on: 27 May 2012, 16:52:41 »
Thanks Rob did think the same as it was running nicely cold last year, so gas may be the solution
« Reply #3 on: 27 May 2012, 21:18:33 »
2.0L auto X reg
Does the a/c compressor 'clutch in' when a/c is on? :-\ :-\
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
« Reply #4 on: 27 May 2012, 21:25:44 »
I've never noticed much difference from it being on or off other than maybe the revs dropping ever so slightly as it first kicks in. I never put it on Eco and often have it on "Lo" but direct it at my feet on a low fan setting. Recharge at least every other year and it seems to work beautifully.
Last week I got out after a 100 mile trip with a boiling face and frostbitten feet. An oddly pleasurable sensation!  :o
Work is the curse of the drinking classes (Oscar Wilde)
« Reply #5 on: 27 May 2012, 21:43:28 »
Last week I got out after a 100 mile trip with a boiling face and frostbitten feet. An oddly pleasurable sensation:o
:o :o Each to their own  :) :) :) ;) ;)
Bob G
  • Gloucester
« Reply #6 on: 27 May 2012, 21:52:36 »
2.0L auto X reg
Andy
yes it does, the air is coll and although told it will not be chilling it is hotter than you would want.
« Reply #7 on: 27 May 2012, 22:16:08 »
;D
My first omega had ice cold a/c after a recharge . Not much use now as the rad fell to bits  ::)
« Reply #8 on: 27 May 2012, 23:41:43 »
2.0L auto X reg
Andy
Could still be a lack of refrigerant  :y
trainmanone
  • stockport
« Reply #9 on: 29 May 2012, 13:25:41 »
just used these  www.coolcaraircon.co.uk  £65 all in  for service and regass + new hp valve,depends where you live dont cover whole country but they come to you  :y
what was that ??????
markrnorton
  • Essex
    • 2.2 & 2.5 Ginetta build
« Reply #10 on: 29 May 2012, 13:32:06 »
;D
« Last Edit: 29 May 2012, 13:35:43 by markrnorton »
markrnorton
  • Essex
« Reply #11 on: 29 May 2012, 13:34:15 »
Sorry, post above ^^^^^ comment
Strange you should say it fell to bits, when i stripped the water and a/c rads out of my 2.5, the a/c rad literally fell to bits. crumbled in my hands
I usually pay around £55 for a recharge
« Reply #12 on: 29 May 2012, 14:56:38 »
Thats quite common , all the bottom fins just fell out and part of the surround  ::) I removed it some time ago ... opening a window is all thats needed  ;)
Carfix
  • Malmesbury, Wiltshire
    • 1997 & 1998 Omega Elites
« Reply #13 on: 30 May 2012, 10:37:23 »
Same thing has happened with my air con rad on both my miggies. The fins at the bottom have fallen out/distintegrated. >:(
I am just starting to price up a replacement condensor and the price of a gas removal and then re-gas.
Grrrrrr
  • Buckinghamshire
« Reply #14 on: 30 May 2012, 21:20:05 »
Gets a lot of condensation on it and then rusts!
