Solar charger
Started by Shackeng, 29 May 2012, 18:24:27
Shackeng
Quote from: Andy B on 30 May 2012, 23:02:02
Quote from: Shackeng on 30 May 2012, 23:00:40
Thanks for all the help, I shall look for the live feed inside first, but I'm not going to enjoy the grovelling on my back.  :y
Remove the two screws from above the fuse box & pull the whole thing out .............. as far as the wiring behind will allow.  ;) ;)
:y :y :y Only got to find a good earth then. ::) ::) ::)
Quote from: Shackeng on 30 May 2012, 23:03:24.....
There must be loads of earths around the car, the whole body is one!  :y :y
Pin 16 of the diagnostic socket has a permanent 12v supply.
A permanent 12V supply goes to each seat for the adjuster / heater.
The accessory socket relay is fed from fuse 27 which is a permanent live, and doesn't appear to supply anything else critical.
Permanent 12V feeds are generally colour coded red.
Most of them are fused at 20A at the fuse box so a smaller inline fuse at point of connection would be a good idea. As said, this can be tiny, as the solar cell won't pass much current.
Shackeng
Even easier, if the car is phone prewired, is 12v and 0v on the phone loom, behind glovebox...
Shackeng
Quote from: TheBoy on 31 May 2012, 19:12:46
What are the clues to that? It is a 3.2 Elite '51 plate with Bose. :y
Shackeng
4" aerial on roof? If so, likely prewired for phone :)
Shackeng
#39
Quote from: TheBoy on 31 May 2012, 20:43:16
Yep, thanks for that Jaime, I'll have a look, but the glove box will still have to come out! :( :( :(
PS How will I recognise the phone loom?
Quote from: Shackeng on 31 May 2012, 20:46:37
Yup, about 15 mins to remove glovebox :)
Phone prewire is a MID type plug (actually, more accurately, a CID type plug), but 16 pin (IIRC). Usually secured to loom/duct behind glovebox with masking tape. Very obvious once glovebox out normally :y
Shackeng
Quote from: TheBoy on 31 May 2012, 20:49:59
That's like Klingon to me ;D However, if I look for an unused plug it should be the one. :y
Quote from: Shackeng on 31 May 2012, 20:52:57
Ah, yes, sorry, thought you'd had a MID out before.
Yeah, its pretty obvious :y
If not, post up pic with glovebox out, somebody will show you :y
