Solar charger
Started by Shackeng, 29 May 2012, 18:24:27
hercules
i spent a day with the company who do this
http://www.solartechnology.co.uk/shop/foldup-solar-panel.htm
as with any solar panel the battery has to be in good condition
Shackeng
Quote from: TheBoy on 31 May 2012, 20:55:44
If not, post up pic with glovebox out, somebody will show you :y
There you go again, crediting me with skills I don't have! ;D
Martian
Quote from: Shackeng on 30 May 2012, 15:51:53
Thanks Dave, mine says it is rated at 2.4W, so I guess it will give about 1.75w in good sun, which will at least help. :y
2.4W will give you 200mA.
Shackeng
Quote from: Martian on 01 June 2012, 15:36:48
Absolute best case scenario. ie, on the equator in unbroken sunshine, and not through a tinted bit of glass.
Although I suspect even then its flawed, as it will need to be above 13v to put anything back in battery I would have though ;)
tigers_gonads
Quote from: TheBoy on 01 June 2012, 15:59:56
I bought a similar one from maplins last month for £12:99 (normally 25 quid)
2.4 watt output and I can confirm that it pushes out a good 19 volts (no load) when its wedged between the sunroof and the sunroof blind on a sunny day.
Can't fault it tbh
Quote from: tigers_gonads on 01 June 2012, 16:07:14
That has no meaning...
tigers_gonads
Quote from: TheBoy on 01 June 2012, 16:08:19
Ok, its not enough to charge a car battery unless you don't mind waiting 6 months but it will keep it topped up as long as the battery is in a fair condition.
Quote from: TheBoy on 31 May 2012, 20:55:16
Quote from: Shackeng on 31 May 2012, 20:52:57
Quote from: TheBoy on 31 May 2012, 20:49:59
Phone prewire is a MID type plug (actually, more accurately, a CID type plug), but 16 pin (IIRC). Usually secured to loom/duct behind glovebox with masking tape. Very obvious once glovebox out normally :y
That's like Klingon to me ;D However, if I look for an unused plug it should be the one. :y
Ah, yes, sorry, thought you'd had a MID out before.
Yeah, its pretty obvious :y
