Author Topic: Oil on spark plugs  (Read 1514 times)
roberts_1409
  • Lincoln
    • Vectra and Omega
Oil on spark plugs
« on: 29 May 2012, 19:42:15 »
Just started servicing my 2.5 V6 noticed oil sat on top of the spark plugs.
Is this normal?
Wanna make sure Its ok, because its going to Europe this week!
Cheers
Re: Oil on spark plugs
« Reply #1 on: 29 May 2012, 19:43:40 »
Is this normal?
Cheers
If you mean "oil in the plugwells", camcover gasket/s leaking due to blocked crankcase breather system. Check "Maintenance" guide
« Reply #2 on: 29 May 2012, 19:48:10 »
Oil in spark plug wells is not normal. It means the cam cover gaskets are leaking, if left HT leads can break down & you could easily develop a miss fire. Personally I would not undertake big miles with them leaking.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 30 May 2012, 17:45:26 »
I agree with the guys above about issue is more than likely cam cover gaskets.
Tunnie I understand exactly what your saying about leaking cam covers. That said I have had instances where people have had leaking cam covers plus cambelt needed replacing.. I would then suggest living with cam covers leaking as that can not ruin your engine, granted over a long period of time leads, dispack could suffer, yet not changing the cambelt could result and has several times in expensive engine repairs.
