Author Topic: FS/ Resonator Box - Dual Ram Removal  (Read 2232 times)
dazzerM
  • Reading
  • Mokka 1.7CDTI, BMW 120D Shadow (It’s a work car)
    • Which ones closest
« on: 29 May 2012, 21:53:34 »
Super rare resonator box designed to remove the dual ram set up on any v6 vauxhall omega. Comes with working air flow meter and all blue silicone hoses, clips etc. Everything to fit straight on. Will fit onto standard airbox
The 2 blue hoses for the throttle body could do with replacing due to being very tight to fit onto the throttle body with the clips etc. Plus they have been trimmed and look a bit tatty. But they do fit on with a lot of fiddling and swearing
I will leave everything connected so you don't have to work out what goes where. Just fit it straight in
Sits close to the engine pulley but it will NEVER hit so don't panic when you fit it an see how close it is.
This removes the dual ram set up. Evens the power out through the whole rev range and a much better flow over around 4000rpm. Pulls all the way to the limiter with no flat spots
Price £130.00 item in RG41
(will update with more pics tommorrow)
Darren
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: FS/ Resonator Box - Dual Ram Removal
« Reply #1 on: 29 May 2012, 21:56:31 »
what like this ;D ;D ;D
dazzerM
  • Reading
« Reply #2 on: 30 May 2012, 06:38:49 »
 ;D ;D ;D It was getting late in my defence  :y
Darren
