Author Topic: Central Locking inop UGRENT!  (Read 2065 times)
roberts_1409
  • Lincoln
    • Vectra and Omega
« on: 29 May 2012, 22:10:28 »
My fuse has just blown for the speedo/rev counter, radio and other bits and bobs, shorted out.
Happened before, but when I replaced the fuse everything worked again including central locking.
For some reason now, my central locking doesn't work. Can't find a separate fuse for it anywhere.
Any ideas why??
Going away so NEED it to work to lock my boot!
Thanks
Re: Central Locking inop UGRENT!
« Reply #1 on: 29 May 2012, 22:20:57 »
Thanks
 ??? ??? ??? Preface lift boots use your key to turn to vertical
facelift don't need a key .....  :-\ :-\
roberts_1409
  • Lincoln
    • Vectra and Omega
« Reply #2 on: 29 May 2012, 22:59:01 »
its either seized or had a key/lock change
« Reply #3 on: 29 May 2012, 23:00:35 »
its either seized or ...
probably due to lack of use .......  ;) ;) ;)
« Reply #4 on: 29 May 2012, 23:02:54 »
I had to force a lock on a previous car to the point when I though the key would snap, it didn't, spray in some wd40 and be brave..... :y :y
roberts_1409
  • Lincoln
    • Vectra and Omega
« Reply #5 on: 29 May 2012, 23:29:37 »
Might give it a go, I'll get intouch with the old owner see if he ever used it. Was seized when I got it.
Only key I got :/
