Author Topic: vibration  (Read 2664 times)
Bob G
  • Gloucester
vibration
« on: 30 May 2012, 17:43:25 »
For variyning reason I found myself in 80mph bracket and noticed a vibration now its not coming from the wheels, my reason for that is the steering wheel is rock solid, seems to vibrate as though engine is missing, once speed drops to 70 or belwo it goes away.
Space left for the replies laong dont drive at at 80+ then  ;D ;D
So any ideas please.
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
Re: vibration
« Reply #1 on: 30 May 2012, 17:46:45 »
failing coil pack or failing leads.....?
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: vibration
« Reply #2 on: 30 May 2012, 17:49:08 »
Your tyres all ok? I had a rear tyre with a bulge on the inside wall that made driving at similar speeds a problem. I was scratching my head until I got home and got under properly to find it.
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: vibration
« Reply #3 on: 30 May 2012, 21:24:16 »
 ive had the same problem at 70+mph mine was caused by a severe pothole which dented the inner rim of wheel. ;)
« Last Edit: 30 May 2012, 21:25:58 by noel »
Bob G
  • Gloucester
Re: vibration
« Reply #4 on: 30 May 2012, 22:09:33 »
They do need replacing as do the bushes, so maybe that might be the cause, will update.
Re: vibration
« Reply #5 on: 30 May 2012, 22:17:07 »
Got the same between 79-85 Bob. Vibration seems to emanate from the floorpan, never sussed out the cause :-\
mathewst
  • Split, Croatia
    • v40
Re: vibration
« Reply #6 on: 30 May 2012, 22:42:21 »
I remember someone here also said discs could be the problem
Re: vibration
« Reply #7 on: 30 May 2012, 22:48:36 »
Vibration throughout the whole car is often an unbalanced or buckled rear wheel or perhaps a failing UJ in the prop shaft.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: vibration
« Reply #8 on: 31 May 2012, 17:25:25 »
I had that on the Tractor Estate (but did not know what the problem was) until a rear tyre exploded on the M40 with the car fully laden with heavy PA gear
