Bloody MV6, I need a match as well!
Started by TheBoy, 30 May 2012, 18:19:40
Well, not the MV6's fault. Friggin', crappy, useless, poorly made, shitty horrible facelift doors that are fitted  >:(.
Of all the times it could have chosen, grrrrrr  >:(
Gonna need some bits by the weekend. Thats going to be a tall order on a Wednesday night now.
Cock, and double cock.
Quote from: TheBoy on 30 May 2012, 18:19:40
Needless to say I blame RobG. My mum always said never to trust a Bristolian  >:(
;D
Rob - guess which bits I didn't salvage from the old, now scrapped, doors?  Guess whats broken?
Check strap after a particularly irate throw-open of the door? ;)
Nearly chrisgixer, the window mech. Cheap, nasty, horrible facelift plastic snapped where the wire meets the window
Martian
Quote from: TheBoy on 30 May 2012, 19:08:14
I've just replaced both the front regulators on the Beemer (common fault), the only saving grace was they cost £48 each for the replacement and took less than an hour to fit for both sides.
fronts are easy on Omega too :y. And Rover 25s ;D
Never done a rear, but suspect it cant be that hard *IF* a can stay in tat position long enough...
Darth Loo-knee
I know where there are some of those too Tinkie :-*
If you think they're bad, don't buy a Golf. Or any of it's clones. Window regulators fail regularly. The roadside 'fix' is to remove the doorcard, prop the glass in the up position, and jam it in place with several paper wedges.I've done dozens of these.
The replacement comes a sealed unit that is 'simply' bolted in place.
Not the same then..? :-\
As on another thread.
Of the 5 omegas I've had, I've never...
...oh never mind.  :-X   ;D
Quote from: chrisgixer on 30 May 2012, 21:10:44
Only ever seen 2 non functional windows on Omegas. Both on the inferior facelift model.
henryd
Quote from: Nick W on 30 May 2012, 20:28:27
You can buy just the cable kit for a MK IV ,lot cheaper too :y
other rides
Actually I've got a spare door here... Or will law of sod mean mine will break the second I give the relevant part away..?
Probably. :D
Quote from: chrisgixer on 30 May 2012, 21:12:56
Probably. :D
Rear, not front ;)
