Author Topic: Oil change for 2.2 petrol ?  (Read 2021 times)
OmegaAnglesey
« on: 30 May 2012, 20:48:58 »
Hi all  :) , I'm thinking about changing the oil and filter on my Omega within the next week or so but since owning it have never changed it, I would appreciate it if anyone chould recommend a link to eBay or somewhere or a shop, For Oil and a Filter for a Omega 2002 2.2i 16v Petrol Automatic Saloon with almost 104,000 on the clock, And is there any special way to do the oil change on Omega 2.2's?, Any other advice welcome... Thanks  ;)
SMD
  • London
    • :( nowt
Re: Oil change for 2.2 petrol ?
« Reply #1 on: 30 May 2012, 20:55:59 »
Recommended VX own brand 10W-40 semi synth oil, bargain on trade club. Use genuine filter too. Nothing different about changing oil on Omgas but the filter housing may be stuck.
Jukeboxnut
  • West Sussex
    • 2004 2.2 auto CDX estate
« Reply #2 on: 30 May 2012, 21:59:48 »
It is a cannister oil filter on the 2.2 and is very easy to acess from underneath the car once the plastic undertray is removed, but you might need a removal tool if it has been overtightened
SMD
  • London
    • :( nowt
« Reply #3 on: 30 May 2012, 22:05:41 »
Of course it is, my bad  :y
78bex
    • 2.2 CD AUTO / FAZER 600
« Reply #4 on: 30 May 2012, 22:39:51 »
re. oil filter removal : I`ve tried strap wrenchs etc which usually slip off, I`m only a keen amateur mech.  Smashing a screw driver thru does work, but is messy. So I got one of these from fleebay... Draper Expert 3 Leg Oil/Fuel Filter Removal Tool.  £10 & postage is extra.
flyer 0712
« Reply #5 on: 30 May 2012, 22:53:45 »
Hi    easy to do..i use a filter strap wrench...genuine v.x.oil  and oil filter..and dont forget a new sump plug complete with rubber ring type washer...cheap enough... :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #6 on: 30 May 2012, 22:55:52 »
.... and if you have a stupidly small oil pan like me don't forget kittylitter to take the spillages away.
note to self, must make oil pan expansion
RIP Paul Lovejoy
« Reply #7 on: 30 May 2012, 22:59:04 »
http://www.machinemart.co.uk/shop/product/details/14-litre-oil-drain-pan
 :y :y
Webby the Bear
  • Northampton
« Reply #8 on: 30 May 2012, 23:12:53 »
 :y :y
cheers tunnster  :y :y
RIP Paul Lovejoy
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #9 on: 30 May 2012, 23:58:59 »
i done filter from above and used a old cardboard box to direct it to the 99p tesco bowl
then i cleaned the bowl out with my sons t shirt out of the white charity bag that came through the letterbox and then gave the bowl to my wife as a gift to help her with the washing up.........
« Last Edit: 31 May 2012, 00:10:07 by bigtimecube »
OmegaAnglesey
« Reply #10 on: 31 May 2012, 03:32:22 »
Thanks for the info  :y  Looks like i'll be going to a local VX dealer with a goodies bag to fill up  ;D
Any much point in changing anything else if everything seems fine i.e spark plugs, etc
Oh and yeah my air con is like a car with no air con ive never re-gassed it before where is the best place to do this i presume VXdealer are a big no no on price. Any Advice welcome  :)
markrnorton
  • Essex
    • 2.2 & 2.5 Ginetta build
« Reply #11 on: 31 May 2012, 08:02:43 »
Just did this last weekend on my 2.2
oil filter can be got to from under the bonnet, i managed to get a strap wrench on it, easy change
oil 10-40 semi , sump plug has a 'star' type drive, so make sure you have one
made my car alot quieter with the oil change
