Author Topic: Air intake??  (Read 5315 times)
horsecow
  • Omagh
    • 2.2 dti cdx/3.2 elite
Air intake??
« on: 31 May 2012, 21:31:17 »
Had my omega for a week now and loving the sound of the v6. Was thinking of fitting a sports air intake/induction kit to give it a bit more roar, but have seen some threads on here which say its a bad idea. Any thoughts guys??
Drive 'er like yer late for mass!!
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
Re: Air intake??
« Reply #1 on: 31 May 2012, 21:33:43 »
Some non standard filters that need to be oiled contaminate the MAF sensor with the oil
TC and BnQ Trade holder.
martin42
Re: Air intake??
« Reply #2 on: 31 May 2012, 21:34:09 »
Each to there own really :y
horsecow
  • Omagh
Re: Air intake??
« Reply #3 on: 31 May 2012, 21:36:01 »
A mate told me that a diesel omega intake would give me the desired noise, any thoughts on this??  ???
Re: Air intake??
« Reply #4 on: 31 May 2012, 21:36:34 »
Be careful of oiled filters, they ruin the MAFs.
Additionally in every single case I've seen, not usig the standard setup has reduced performance.
Re: Air intake??
« Reply #5 on: 31 May 2012, 21:37:27 »
Diesel Omegas use virtually the same airbox setup. Methinks you mate is talking guff ;)
horsecow
  • Omagh
Re: Air intake??
« Reply #6 on: 31 May 2012, 21:38:22 »
I'm not looking for any more performance, more than happy with whats there would just like a bit more grunt with the power as its fairly quiet at the minute!!
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
Re: Air intake??
« Reply #7 on: 31 May 2012, 22:12:37 »
I've currently got a small hole in the exhaust just after the middle box. A real growler!
Swap?!  ;)
Work is the curse of the drinking classes (Oscar Wilde)
tgm147
  • Wirral
    • '02 2.2 Omega CD
Re: Air intake??
« Reply #8 on: 31 May 2012, 23:25:08 »
Drill your airbox then. Big drill bit and stick some holes in the base of the airbox and the side facing the wing. You'll get a nice roar. I stuck a K&N panel filter in mine too.
horsecow
  • Omagh
Re: Air intake??
« Reply #9 on: 01 June 2012, 07:11:01 »
cheers tgm sounds like a plan.
Thanks grrrr but i think I'll try tgm idea 1st  :y
Re: Air intake??
« Reply #10 on: 01 June 2012, 09:44:04 »
Not having your centre section connected to back box, helps with noise  ::)  :-X
mathewst
  • Split, Croatia
    • v40
Re: Air intake??
« Reply #11 on: 01 June 2012, 11:23:22 »
Try drilling holes in that flexy tube on the middle exhaust  ;D
When on my old Lancia it went 1.6 litres roared like dodge viper with a blown exhaust.
Could be heard from far FAR away   :D
But it was damn embarassing to drive like that
Re: Air intake??
« Reply #12 on: 01 June 2012, 11:31:40 »
Problem is, it's then taking in warm air from the engine bay, which is a real performance killer.
If GM could have avoided that duct that runs round to the front of the radiator, they would have done. Nobody believes that the standard air intake is optimal, yet, as said, nobody has yet truly improved it. ;)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Air intake??
« Reply #13 on: 01 June 2012, 13:26:07 »
Stick a microphone inside the Plenum just behind the Throttle Bodies and connect it to your stereo, your soon get bored with the noise.
Re: Air intake??
« Reply #14 on: 01 June 2012, 13:44:18 »
Considering the big v6 under the bonnet they are quite though , only time i ever hear anything is when there is a slight rasp from the tail pipe  ::)
